Question about Kitchen Ranges
What is the hose on the side of the dishwasher for. what does it connect to.
A rubber hose from a dishwasher should be the drain hose that goes to the sink drain or garbage disposal. (The metal/copper pipe should be the hot water supply pipe).
Posted on Oct 16, 2010
Can the dishwasher hose intake be rotated so that the hose does not have to loop around the disposal?
You can cut off the dishwasher hose so it is shorter, but that might not give correct end for connecting to drain tailpiece. See if end of dishwasher hose has built-in fitting.
They sell universal connections that fit both the dishwasher hose and the drain tailpiece... but check what is available at hardware before cutting off dishwasher hose.
The drain tailpiece can be taken apart and then rotated so dishwasher hose can come from different direction. This requires removal of p-trap, and cleaning of each part before reassembly.
If this is double sink, the disposal can be moved to other side, and sink basket with tailpiece move to other side.
Following link has step by step tips for taking apart P-trap and reassembling tubular drain pipes so they don't leak: and installing disposal if you switch sides on double sink
http://waterheatertimer.org/How-to-install-vent-under-sink.html#apart
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Electrical Supplies
Want to remove present dishwasher for replacement with a new one. How do you do it.
Most dishwashers are housed in a cabinet next to your kitchen sink.
Not knowing how exactly your machine is set up I will just advise you on common setup features and removal.
First open the doors to kitchen cabinet under the sink. If you see two hoses connected under the sink, they most likely are from your dishwasher. One is an inlet hose which would be connected to a water tap. The other would be a drain hose which would be connected via a clamp to the drain under your sink.
Turn off water tap to remove inlet hose. Unscrew or undo the clamp fixing your drain hose to drain pipe. Note when you remove the drain hose the hole to the drain pipe is exposed. You need to block this off as it will leak water when ever the sink is running. I normally get a plastic bag and twist it inside the hole and tape it off.
Next you need to locate the power cord and plug for the dishwasher. This is normally under the sink cabinet as well. However, check either side of the dishwasher. Sometimes they are behind the dishwasher.
Once you have disconnected the hoses, open dishwasher door. Look on the inside walls of the dishwasher. Some models are screwed into the wall of the cabinet so you need to unscrew machine. The screws go in either from the side walls or from the inside roof of dishwaser to your benchtop.
You need to also remove the kitchen kickboard if one has been installed infront of the dishwasher.
When machine is free open the diswasher door and grab either side of door and gently pull machine out. Have someone help you feed the hoses through as you pull out.
If the machine does not easily pull out check again for hidden anchor screws around the edges of the machine or even clamps which fix the hoses to the cabinet.
If you have issues pulling it out see if you can take some pictures and I will help you.
ash
Sep 11, 2011 | Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
Dec 17, 2008 | Bosch SHU3305 Dishwasher
Hooking carbage disposal to diswashing not sure where it hooks on the dishwasher itself
Waste line from dishwasher to waste connects to one of
  • small spigot on extension pipe above the disposal up high under counter
  • small spigot on side of disposal directly above sewer connection, below blade
  • small spigot on sewer line below disposal, but above U trap
at the dishwasher end, the hose connects to the pump output, under the base of the dishwasher, usually left side of center, there is no external spigot
you have to run the waste line under from the back, and connect from the front , by removing the kick plate under the door opening
Oct 30, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Installing a bosch dishwasher SHE44C06UC
just clip it to the side.  I had the same questions after ours was installed wrong
Jul 31, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
SHX46L05UC Dishwasher
You cannot access the drain hose "internally" you will need to pull out the dishwasher and probably on the left side if facing underneath the drain hose will be connected with a screw clamp most likely.
Feb 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Side Hose
The hose on the right is a breather and should not be connected.
Sep 17, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
