Question about Dryers
I need wire diagram lit8528187 for a whirlpool dryer ler4634jq1 your help will be appreciated
appldoctom
  • 311 Answers
SOURCE: Need belt diagram for Whirlpool Dryer LER5636P
its on the bag of a new belt.but its eazy to put on .put the belt with ribbs down on the drumthis is with the drum on the rollers in the dryer .now have the idler pulley in place and put the belt in between the idler pully roller and the pully bracket,then pull back on the pully and place belt on motor pully.check alinment before starting or will throw belt off again.God bless,tom
Posted on Jan 01, 2009
RepairClinic
  • 32 Answers
SOURCE: No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Posted on Feb 05, 2009
hiltonjug
  • 612 Answers
SOURCE: wire diagram 4 whirlpool dryer wed8300swo
I can't find a diagram but I can tell you. The two out side are your hot and the center is nutral. If you are putting a four wire on, it just adds a ground to the three.
Please rate solution
Posted on Sep 07, 2009
sleprocks
  • 147 Answers
SOURCE: My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
Posted on Oct 21, 2009
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Ler4634jq1
The longest distance possible will help with the lint build up don't kink your hose to a 90 degree angle as it will block air flow. Curves are fine and you sould allow for a little leway as you may need to move the dryer at some point .
Jul 17, 2013 | Whirlpool LER4634J Electric Dryer
My aunt needs basic operating instruction manual for whirlpool dryer mdl ler4634jq1
Hello your manual can be found here at this link click here http://www.managemylife.com/mmh/owner_manuals/17474/WHIRLPOOL-Residential-Dryer-L0710453?brand_name_search=ler4634jq1 if you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your search for you dryers manual. By doing this it allows me to continue helping others in similar situations in the future. Thank you,
Rick
Oct 01, 2011 | Whirlpool LER4634J Electric Dryer
My dryer does not start when i hit the start button. I have checked power to the dryer, it is good. I have taken my digital multimeter, to check start button, that tested fine. I checked all connections on...
It is probably one of the limit switches inside the dryer most likely the high limit went bad and will not allow the dryer to run or the door switch could have gone bad these are two very good places to start check the door switch first and if that checks out I would check the high limit.
Jan 17, 2010 | Dryers
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
My whirlpool dryer model number LER4634JQ1 is not getting hot
You need a 30 amp breaker in my neck of the woods. South Alabama, US
Jul 28, 2009 | Dryers
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not spin
Usually if a dryer won't spin, I suggest checking the belt to make sure it isn't broke or even the motor burned out. If you post a model number for your dryer, I may be able to assist you further.
May 28, 2008 | Dryers
Dryers Logo
173 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
