Question about Canon Rebel XT / EOS 350D Digital Camera
Error message on screen when flash pops up
I am having a problem with my Camera. An error message comes on the screen once the pop flash pops up
  • 1 more comment
  • Anonymous Jun 05, 2008
    error01 and error99 appears when flash pops up
  • Anonymous Jun 06, 2008
    error01 and error99
  • mikeadderley Jan 19, 2009
    When the flash pops up it says busy then error 99.
    What can I do please
    Novelist:
  • 130 Answers
What is the error message you are getting?
Posted on Jun 04, 2008
I am getting this message on my EOS 450d, (camera's built in flash pop up was obstructed turn the power switch to off and on again). I have done this several times the flash wont pop up - can you please...
Sometimes the pop-up flash on the EOS range of cameras can get stuck. The EOS family have a very tiny micro switch under one blade of the flash hot-shoe.
Get a toothpick and manually pop the switch. It should clear your error, too.
Good Luck.
Mar 28, 2011 | Canon EOS 450D Digital Camera
I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
Sai.
Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Lens goes in and out and error message 'turn
this message comes up if you have dropped your camera. try tapping the device while the message comes up. if that doesn't work then you have to take it to the sony service centre to replace the lens array. it costs about 60$ to replace it.
Jul 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos flash beeps 3 times and won't pop up. error 5 comes up on lcd screen. tried turning off, removing card and battery still have problem.
Typically this happens when the pop up flash is jammed. Go into P mode and press the manual release on the left side to pop up the flash. Wiggle and giggle it. It seems to happen after being packed with something resting on top of the flash unit. I thnk it simply gets slightly out of alignment.
Good Luck.
Feb 22, 2009 | Canon Cameras
Flash Error
The error 5 can mean that there is something blocking the flash from popping up. If it is up but still get the message then you need to check to see if the little black pin/stick that lets the camera know that the flash is up, is not stuck. With the flash up and pointed at you ( like you are going to take a picture of yourself) the pin is located on the right side close to the where the flash attaches to the camera. Yo should see a little pin sticking up. make sure that area is free of dust and /or debris. if it is not up then that is the problem. try to free it with out braking it or get it professionally repaired.
Jul 08, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Built in flash dosen't pop up
5 error is a mirror return error.
The reason or this error message is that the mirror not is returning after a shot. To normalize the camera, a second press on the trigger button is necessary. 4. Note that all functions operate perfect, and the mirror slides smooth in its trace.
The 5 error often happens when using 3rd party lenses (Sigma, Tamron, etc.) which cause incompatibility problems. Were you using a non-Canon lens?
Also clean all contacts with a pencil eraser. Do this with your battery contacts as well and try fresh batteries.
Jun 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Enjoy.
Jan 20, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Built in flash not popping up
Error 05 means - Something is obstructing the built-in flash.... Try to reclean it. Good luck!
May 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
