Question about Homelite Garden
My Homelite chainsaw 33cc zr10926 won't engage when the cord is pulled.
    Brigadier General:
  • 4,088 Answers
Remove the starter mechanism from the engine and examine the 'dogs' which engage the flywheel. They either damaged or their pivots are frozen with dirt and other debris. Hope this helps!
Posted on Oct 16, 2010
SOURCE:
Switch turns off
try pulling the starting rope a little bit out before you pull start it. If this does not work replace the switch.
Sep 08, 2014 | Homelite ZR10926 16 Chain Saw
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
The starting cord broke on my Homelite Chain Saw. how do i tie it back on?
GO TO THIS LINK AND SEARCH FOR IT.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Homelite ZR10926 16 Chain Saw
Starts but won,t keep running seems fuel starved still quites with the choke full or half or off homelite 33cc ut10947 thank you
Possible fuel starvation, pull the fuel pipe out of the tank through the fill hole and replace the filter on the end, let us know how you get on,
Feb 05, 2011 | Garden
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Homelite ZR10926 16 Chain Saw
HOMELITE CHAIN SAWS LOOKING for a parts manual to repair and replace damage parts. model ut109470 33cc family 4hcps0384aa sin #AGO780395-03-4 Can you help
Go to: http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF&app=HNL531&...
This gets you to drawings and part numbers of the entire saw. Also, for an excellent article on the Walbro carburetor, go to: http://www.drystacked.com Hope this helps!
May 02, 2010 | Homelite ZR10926 16 Chain Saw
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
Where can i buy a replacement chain for the expand-it prunner emmanuel1942@yahoo.com
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Mar 26, 2010 | Homelite Expand - It 10" Pruner Attachment
Garden Logo
124 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
