Question about Kidde Nighthawk Combo Gas/co Detector
It chirps once every 30 seconds. - Kidde Nighthawk Combo Gas/co Detector
  • 100 Answers
If battery operated need to be replaced
Posted on Oct 16, 2010
My 2001 ford focus keeps locking. The power locks automatically lock as soon as I unlock them, barely enough time to open door.
Your Focus may be equipped with the autolock feature. Try this:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Feb 18, 2015 | 2001 Ford Focus
After I set alarm, it chirps once then 2 seconds later it chirps once again!!
That second chirp is a status alert letting you know a zone was not able arm yet. Most common reason is that the dome light its not out yet. It arms itself as soon as the trigger goes to sleep.
May 01, 2014 | Vehicle Parts & Accessories
Smoke detector keeps chirping after battery is changed, chirps every 30 seconds. chirps come from the ceiling not the device
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
Aug 11, 2013 | Kidde Home
My theft light on my 1998 Lincoln Navigator is on and the car won't start.
Deactivating/activating the autolock feature...
Before following the procedure, make sure that the ignition is OFF and all vehicle doors and the liftgate window are closed.
You must complete steps 1-5 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
6. Press the unlock control, then press the lock control. The horn will
Also, if your vehicle is equipped with a coded-key anti-theft system. Only the correct key will be able to start your vehicle. If your keys are lost or stolen, you must take your vehicle to a Ford/Lincoln-Mercury dealership for re-programming.
Programming additional keys If you need additional keys electronically coded for your vehicle, spares can be purchased (a maximum of 16 keys can be programmed). To program a new key, perform the following procedure:
1. With the coded key in the ignition, turn the ignition from ON to OFF.
2. Within 15 seconds of turning ignition off, insert the new coded key
into the ignition and turn it from OFF to ON or START. If successful, the
THEFT indicator light will illuminate for two seconds. Repeat procedure
for all new keys.
If key coding fails, the THEFT indicator light will flash.
Coding failure can be caused by any of the following:
² The new key was not inserted into the ignition within 15 seconds.
² 16 keys have already been programmed.
² The new key does not have an electronic code.
Other details can find in the 1998-Lincoln-Navigator-Owners-Manual
Good luck (remember comment and rated this).
Jul 09, 2010 | Cars & Trucks
How do I de-activate the automatic power door locks? 1998 Ford Expedition Eddie Bauer Edition. (also - same thing happens to the 1995 Lincoln Town Car). Any Suggestions?
here is the instructions,i had to type it out because the picture was too large.Its actually for my 2000 Ford,give it a try because it might work.
Before following the procedure,make sure that the ignition is OFF and all vehicle doors are closed.You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated.If the procedure needs to be repeated,you must wait 30 seconds.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control three times.
3.Turn the ignition key form ON to OFF.
4.Press the power door UNLOCK control three times.
5.Turn the ignition back to ON,The horn will chirp.
6.Press the UNLOCK control,then press the lock control.The horn will chirp once if autolock was deactivated or twice(one short and one long chirp)if autolock was activated.
7.Turn the ignition to OFF.The horn will chirp once to confirm the procedure is complete...Page 89 of the owners manual
about the Town car,try it on there as well,it wouldnt hurt it,i just dont have the manual for it.
Feb 25, 2010 | 1998 Ford Expedition
My alarm is chirping every 30 seconds. This is my second one. no light .
An intermittent chirp usually indicates that the battery needs changing, or a battery needs to be installed. If this is a new unit that came with the battery already inside, there is probably a tab located between the top of the battery and the contacts that needs removing before the unit will stop chirping.
Nov 20, 2009 | Home Security
My alarms are chirping every 30 seconds or so. I
Depending on manufacturers and such, the catalyst detector element itself may need to be replaced occasionally. Usually cheaper and faster to just get another detector.
Nov 02, 2009 | Kidde Nighthawk Combo Gas/co Detector
Have a 2008 Chevy Cobalt, tire sensor is staying on all the tire, not reading the tire pressure at all, has 2 dashes instead. Called and talked to dealership mechanic, he said that re-registering the...
On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated....Next
  • Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate....Next
    1. After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    1. Right front
    2. Right rear
    3. Left rear
    4. When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
    5. Ignition OFF, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label
    Jul 29, 2009 | 2008 Chevrolet Cobalt
    Auto Lock Activation
    Deactivating/activating autolock
    There are 3 methods to enable/disable this feature. One through your
    dealer, the second with a power door unlock/lock sequence and the third
    with the keypad.
    Before following the activation or deactivation procedures, make sure
    that the anti-theft system is not armed, ignition is off, and all vehicle
    doors, liftgate and liftgate window are closed.
    Controls and features
    Power door unlock/lock
    procedure
    Keyless entry key pad procedure
    1. Enter 5 digit entry code
    2. Press and hold 7/8 control
    3. Press and release 3/4 control
    4. Release 7/8 control.
    The user should receive a horn
    chirp
    to indicate the system has
    been disabled or a chirp followed by
    a honk to indicate the system has
    been enabled.
    Smart unlock
    This feature prevents the driver’s door from locking while the key is in
    the ignition. This feature will unlock only the driver’s door if the key is in
    the ignition cylinder, the driver’s door is ajar and all doors are locked
    using the interior trim switch. If these conditions are met, the entire
    vehicle will lock and the driver’s door will unlock within 1 second.
    127
    May 15, 2009 | 2002 Ford Explorer
    Kidde Nighthawk Combo Gas/co Detector Logo
    49 people viewed this question
    Top Kidde Home Security Experts
    john h
    Are you a Kidde Home Security Expert? Answer questions, earn points and help others
