Question about Peg Perego John Deere Gator HPX Ride on Toy
How to adjust the seat - Peg Perego John Deere Gator HPX Ride on Toy
    Sniper:
  • 70 Answers
You can turn the gator on the side and you will see 4 red fasteners under the seat, remove them and pull the seat with bolts out and reset into a more preferable set of holes
Posted on Mar 02, 2011
The front seats for our 2003 Escalade will not move forward or backward and the heat control for the front seats will not work.
Does your Escalade have memory seats ?
There are 2 options of power seat systems available in full size trucks. The 6 way driver and passenger power seats, and 8 way driver and passenger power seats with driver memory. For the driver memory seat operation refer to Memory Seats Description and Operation . Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Jan 16, 2017 | 2003 Cadillac Escalade
Tip
How to adjust the seat on an indoor cycle
Video of How to Adjust the Seat on your Indoor Cycle
  • This video will demonstrate how to adjust the seat on your indoor cycle properly
  • Tools needed:
    • Adjustable Wrench
  • To begin loosen the nuts on each side of the seat equal turns
    • Ideally, there should be equal portions of the clamp bolt exposed on each side
  • Once you have them loose you can adjust the seat back and forth on the mounting rails as well as adjusting the angle of the set
    • The best position for the seat is level and in the center of the mounting rails adjustment
  • Once you have the seat positioned as desired finger tighten the nuts on each side of the seat equal turns and then tighten the nuts using a wrench an equal number of turns as well
    • Again, the goal is to have equal portions of the seat clamp bolt exposed on each side
  • This is all that is required to adjust the seat on your indoor cycle.
on Jun 06, 2016 | Lemond Revmaster Revolution Trainer
Tip
Indoor Cycle Seat Adjustment
  • Tools needed:
    • Adjustable Wrench
Video of Adjusting the Seat on an Indoor Cycle
on Apr 28, 2014 | Exercise & Fitness
How do you adjust the seat
Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
Jun 20, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
2001 VW Beetle. The driver's front seat adjuster
I'm assuming you have manual adjustment seats. There is a spring underneath the seat that locks the end of the lever into corresponding notches in the seat frame rail. That spring has either fallen off or broken.
Jan 22, 2010 | 2001 Volkswagen Beetle
How do i remove the front seats of a 1998 Pontiac Grand Prix?
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
Sep 01, 2009 | 1998 Pontiac Grand Prix
Seat adjustment
Passenger seats are usually manually operated from a latch or bar under the front of the seat. the seat back should have a lever between the door and edge of seat to make adjustment pull up on lever push back on seatback.
Jun 08, 2008 | 1990 Oldsmobile Cutlass Ciera
Peg Perego John Deere Gator HPX Ride on Toy Logo
579 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
