Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
TB 525CS does what it is supposed to do with full choke but when I put it in the middle position it does not do anything. Any suggestions?
  • Troy Master
  • 7,482 Answers
Check your fuel filter in the fuel tank,if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 05, 2010
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
Victa carburetor problems
Why you have a car carburetor fitted to a mower troubles me... I think you'll find you don't gain any power increases by having such a large carbie on there, if anything you'll simply flood the engine with air or fuel and will have great difficulty maintaining a stoichiometric ratio.
The fact that the motor will only run on choke indicated that it is getting too much air without choke, and not enough fuel. This would be due to the intake size being still too large and probably a restriction in the venturi flow near the jets causing lack of suction to draw fuel from the bowl which would be due to the mower engine not creating the same vacuum as a car engine.
My honest suggestion?
Put a Victa carbie back on it, it's probably not going to work...
If you want it to run harder, adjust the throttle assembly to rev harder, or change the governor position.
Nov 18, 2013 | Garden
How do I replace the trigger on a TB 525cs? I have the part butneed to know where the spring goes?
Some are easier than others. You will need the correct size hex head screw driver - remove the screws that release the cover exposing the trigger. The spring will go between the trigger and housing.
Gary Rice
Jul 10, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
To choke this bike do you put the lever up or down
should have like 3 clicks down should be choke off middle should be half choke.. all the way up should be full choke
Feb 02, 2011 | 2005 Honda CRF 100 F
Qualcast petrol 35s mower will only operate with choke fully open, closing the choke causes the engine to cut out. Mower has been operating fine until now following a full service. What is the likely...
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
Aug 10, 2010 | Garden
Greetings... My son's crf150f was running rough yesterday [backfiring-wouldn't rev smoothly] with choke in normal "off" position. Setting choke to half choke middle position allowed much smoother...
sometimes they are stubborne,I use stranded electrical wire to send through jets,just make sure when blowing into an orfus that it comes out somewhere hope this helps
Jun 27, 2010 | 2005 Honda CRF 150 F
Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Apr 28, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Replaced the ariginal intake with k and n airfilter individuals, and now at 3000 rpm it boggs down do you have any suggestions.I no im supposed to put bigger jets in the carbs but is there anything else im...
The CV carbs actually prefer still air from the standard air box, but try the choke at 3000rpm and if it helps then it is lean, raising the needles may help at this rpm. may not need bigger mains unless you also have a sports exhaust
remember that to raise the needles you put the circlips in the lower grooves.
Apr 05, 2010 | 1982 Suzuki GS 650 GT
XR 100 didnt move for a year.My bad so i cleaned the carb,jets,floats,needle slide. Motor cycle starts on the 1st kick with choke on full idles fine.When you touch the throtle or click the choke to middle...
First Make sure you have all new fresh gas,and new fuel filter,Then check the intake tube between the head and carb for cracks or leaks,And You'll need to go back through the carb again as this is a carb issue,But without doing the above first,a clean carb won't be clean for long.
May 17, 2009 | 2000 Honda XR 250 R
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
138 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
