Question about Maytag Dishwashers
I have a maytag intelliclean dishwasher supercapacity EQ plus, 12 years old. The washer for the past year or so has steadlly declined in performance. It does not clean dishes well, they are well rinsed before we put them in. Glasses never get very clean usually half have streaks or a film on them. We use a rinse agent as well. Is this machine beyond it's useful life or is there filers or something requiring cleaning? MDB6800awb
  • 11,896 Answers
There could be quite a few things that could cause this. A worn or leaky pump could cause this, a clogged hose or spray arm could cause this, water valves that are not opening fully because they are faulty could cause this.
Posted on Oct 16, 2010
Maytag jetclean dishwasher eq plus
What is the model number?
May 21, 2013 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus, Model MD87100AWW making grinding noises 20 minutes into wash cycle.
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Feb 28, 2010 | Maytag Dishwashers
The dishwasher is probably 12-15 years old. It
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Oct 06, 2009 | Maytag Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
MAYTAG DISH WASHER MODEL 41-ESP4-DISH
I suggest calling Maytag and have a tech come out to look at it. Appliances come with a one year parts and labor warranty.Use it before your one year is up.
Nov 17, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag jetclean EQ plus dishwasher
I had the exact same problem. When the service tech came to look, my husband watched him. There was a disconnected wire to the motherboard which my husband asked can't the tech just reconnect it. The tech stated no, we needed a new motherboard. My husband reconnected the wire using tape for now & the dishwasher is working perfect. My husband is going to get somekind of calk/glue that will work permanently. This should save us from replacing the motherboard for a while. The dishwasher is only about 5 years old! My previous dishwasher was over 20 years old with no repair problems the over 10 years that I owned & used it.
I am looking for the self check test, does anyone know where I can find the instructions how to do it myself? Thank you
Sep 20, 2007 | Dishwashers
Dishwashers Logo
295 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
