Question about Eclipse PA5422 Car Audio Amplifier
How do i connect a single 12" subwoofer to an Eclipse PA5422 amp?
  • 400 Answers
Make sure your switch on the amp is on lpf (low pass filter)....You should be able to bridge that amp....Look where you hook up speakers and see if it has a line over one negative and one positive....Should be outer two screws.
Posted on Oct 17, 2010
Have 2 -12" inch eclipse sw6200 with two positive and negative hook up idk how to hook up from amp
It will depend on the capability of your amp. Each sub has dual voice coils (DVC). Each voice coil is (probably) 4 ohms. If your amp is a single channel, 1 ohm stable amp, you can connect all of the voice coils from both subs in parallel on the amp output. Other configurations will depend on the amp's number of channels and minimum resistance your amp can withstand.
May 01, 2015 | Eclipse Car Audio & Video
I was given the amp and I want to test it with a volt meter to see if it even works. I currently dont have a system .
Easiest way, get any old speaker 4 or 8 ohm and hook it up to channel 1 then plug an rca lead into channel 1, power up amp and touch finger on rca and you should hear pop or scratchy sound from speaker . Audio circuit for channel 1 is good . repeat for channels 2 3 4 .
Mar 17, 2010 | Eclipse PA5422 Car Audio Amplifier
I have two 12 in. subs single voice coil and need to know if could run a 1 omh stablb amp and if yes and how
Yes, you sure could. Each sub is a 4 ohm load. When you put them in a box connect a wire from the + terminal on each speaker, and connect that to the + terminal on the box. Do the same from each - terminal, connecting to the - terminal on the box.
This is called "wiring in parallel" and it will split the load in half, so you present a 2 ohm load to the amp. Since your amp is rated down to 1 ohm, it will work just great.
Feb 07, 2010 | Kenwood 12" 4-Ohm Single-Voice-Coil...
I need to know about my 12" dvc eclipse subwoofer but i dont know what modle it is
Hello brandin_1,
I'm assuming that you have the new 12" eclipse. Look at the sub cone. If it is blue in color, you have the Model SW4210 12" DVC SUBWOOFER, 4ohm, 250W RMS,750W MAX. If the cone is silver, it is the Model SW6210 12" DVC SUBWOOFER, 4ohm, 500W RMS, 1500W MAX.
If it is an older dvc Fujitsu Ten 12" eclipse, most likely it is the Model SW9122. If it is a REALLY old 12" eclipse, it is probably a model 88120.
Hope this helps.
Apr 12, 2009 | Eclipse Car Audio & Video
Tuning
try turning down the lows and highs to bout 3/4 then adjust you mid
Mar 07, 2009 | Eclipse PA5422 Car Audio Amplifier
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Installing PA5422 in two channewl mode
Since your first paragraph is leading to your question paragraph, I'll adress that. "what is the difference amongst the MONO/STEREO/L+R switch options available on both Front and Rear AMP X-over Sections of the PA5422?" Mono is same sound output on each channel, stereo is what you want as it gives out stereo sound, and L+R is most likely blending the channels together.
Sep 23, 2006 | Eclipse PA5422 Car Audio Amplifier
Eclipse PA5422 Car Audio Amplifier Logo
74 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
