Is it hard to replace a dc jack on a laptop? - Computers & Internet
    President:
  • 2,653 Answers
For me, no. For the average user, Yes.
It depends on the model. What model is your laptop?
Posted on Oct 16, 2010
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
X61s no power. No lights when plugged in.using new correct charger
The problem may be the DC jack in the laptop, plug the power supply in and put your hand on the DC jack and slowly apply pressure sideways "not to hard" and at the same time press the power button repeatedly to see if it will start, if yes! the DC jack in the laptop needs to be resold-ed back on the motherboard or replaced. Now! if there is no change I recommend a computer technician look at the system with an estimate in mind.
Jan 10, 2011 | Lenovo ThinkPad X61s Notebook
The input on the laptop where i stick the charger inn isn't working, what do i do?
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop
Oct 09, 2010 | HP 6530b Notebook
My elitegroup laptop was no power at all, then the pin positive is shorted to pin negative
DC Jack diagnosis:
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | EliteGroup G320 Notebook
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
Oct 08, 2010 | Acer Aspire 3680 Laptop
My LG R400 laptop has a bad charging port.how do i repair it
DC Jack diagnosis:
Oct 04, 2010 | LG Computers & Internet
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Computer will not power up. No problems before Turning off
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Toshiba Satellite A215-S4747 Notebook
Tech manual for Asus Z96J lap top. need to replace the dc power jack how do I access the power jack?
For all the function and portability laptops provide, there are also some drawbacks. The biggest problem with laptops is with battery life. To get constant battery power, the laptop has to be plugged into a wall outlet. The wall plug then connects to the DC jack in the back of the laptop. The DC jack is no more than a little piece of metal that conducts the electricity for the computer. These DC jacks are known to be fragile and break off easily. If this happens, you can open the laptop and replace the DC jack yourself.
  1. Step 1 Remove the internal battery pack from your laptop. Flip the laptop over and locate the release button for the battery pack. Hold the button in to slide the battery pack free. It is important that you remove the internal battery pack as well as unplug the power cord from the wall outlet to prevent risk of shock while working inside the laptop.
  2. Step 2 Unscrew all of the screws on the underside of your laptop. The number of screws will depend on the model of computer. There should be one at each corner and then one or two screws that hold the hard drivemag-glass_10x10.gif cover in place. Once the screws are removed, take out your computer's hard drive. Newer-model computers will have a hard drive that slides out of the side of the computer.
  3. Step 3 Locate the two screws at the back of the computer that hold the laptop screen's hinges in place. Once these two screws are removed, gently pull up on the screen until you clear the silver pegs from the holes in the laptop's body. Two wires lead from the screen into the computer, so ensure you do not pull so hard that you disconnect them. Carefully set the laptop screen aside so it does not get damaged while you work inside the computer.
  4. Step 4 Separate the two halves of the laptop's body to expose the computer's internal components. Flip the keyboard on its face, making sure not to disconnect the keyboard's connector. Underneath the keyboard will be a metal plate that covers the computer's motherboard. Unscrew the screws that hold this plate in place and set it aside.
  5. Step 5 Locate the DC jack for the laptop. Most all laptop's DC jack outlets are located at the back left corner of the computer. Using your tweezers, remove the old DC jack. Identify the slot in the motherboard that the old DC jack came out of. If the DC jack was loose before you removed it, there will be a small slot at the base of the opening in the back of the computer that the DC jack pops into. Using the tweezers again, slide the new DC jack into this slot until you hear a clicking sound. To hold it in place you can solder the new jack to the motherboard, or simply superglue it in place. Don't use too much superglue or you will risk losing the ability for the jack to conduct electricity.
Nov 14, 2009 | Computers & Internet
Acer 9100 dc jack broken
search ebay for a DC Jack for your model. Disassemble your laptop. Desolder the broken DC Jack from the laptop motherboard. Solder the new DC jack onto the motherboard and reassemble laptop. If your not experienced in soldering of disassembling laptops I would recommend you hire someone to do this job. If you wish contact me jason@jrdtech.net
May 13, 2008 | Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
