Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do i mix the colours on my stylus sx115 as i have run out of black but have the other 3 colours remaining?
Conserving Black Ink When the Cartridge Is Low (For Windows Only) The window below appears when black ink runs low and there is more color ink than black ink. It appears only when plain papers is selected as the paper type, and Text is selected as the Quality Option.
The window gives you the option to either continue using black ink normally or conserve black ink by using a mixture of color inks to create black. Click the Yes button to use a mixture of color inks to create black. You will see the same window the next time you print a similar job. Click the No button to continue using the remaining black ink for the job you are printing. You will see the same window the next time you print a similar job, and again have the option to conserve black ink. Click Disable this feature to continue using the remaining black ink.
Posted on Oct 18, 2010
Epson sx115 wont print because it says its run out of one colour how can i get round this
The answer is on the error message. It needs another ink. So I advised you to buy a new one in the local computer store near you.
Jul 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My epson stylus SX115 won't print out.....It says no black ink, but it has color........
Epsons will not print at all if ANY of the cartridges are empty. It doesn't matter whether or not you want to use the color exclusively or not.
Apr 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How many colours are available eg black, cyan etc
This printer has 4 colour cartridges, black, cyan, yellow and magenta.
It can generate a wide range of colours by mixing some or all of these inks to produce a colour photo images.
Feb 24, 2011 | Epson Stylus C86 InkJet Printer
How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
ftp://download.epson-europe.com/pub/download/3233/epson323393eu.pdf
Mar 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson C46 - is it possible to set the printer so that it combines colours to produce black. My black cartridge just won't print, I've replaced it, cleaned it, power cleaned it. I know that when the black...
Printing black through color mixing is very expensive!
Try this:
Remove the cartridges and print head.
Make a moxture of 15-20% ammonia and warm water solution.
Soak the head for an hour then completely dry it ,especially the electrical contacts.
Run a cleaning cycle and see if your nozzle check pattern improves.
If so run another clean and recheck or soak it again.
Thanks for using FixYa.
Jun 20, 2009 | Epson Stylus C46 InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cyan ink low
If one of the colours are low, it will try mixing the remaining colours as best it can (the exception to this is the black ink). However, this is only a bandaid as far as the printer is concerned.
May 19, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
807 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
