Question about Samsung Refrigerators
Samsung SRL679/709 The lights in the fridge still does not work even after replacing the bulbs with new ones, and now the special feature tune (for a reminder when one have left the door is open), does not stop ringing( every 2 minutes! ) I suspect that perhaps the small switch that controls the tune and the lights have blown? Do you agree? And is this someting that I can fix myself? Annie
  • 66 Answers
SOURCE: whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Posted on Dec 26, 2007
dcp2
  • 63 Answers
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Posted on Jan 28, 2008
PARA REGULAR LA TEMPERATURA EN UNA
NEVERA SAMSUNGSR-688EVCON TEMPERATURA CONTROLADO POR SISTEMA ELETRONICO
Posted on Mar 11, 2008
hapndnvegas
  • 35 Answers
SOURCE: How to reset fridge light - Kitchenaid side by side
this may or may not help. Most SMART devices forget their SMART functions when your unplug them and wait a few seconds then plug them back in this should reset it!!
Posted on Apr 13, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
Can you show me where to replace the light bulb for a Samsung Fridge model no: SR52NXA
Click on to a parts supplier like ShopJimmy.com and pull up their super photos of the guts of your unit. The photos will show you exactly where that bulb is located. Easy job.
Oct 13, 2014 | Samsung Refrigerators
Rl41WGIH fan on but no light and fridge isn't very cold
Bad news for you. I've had the same symptom. The problem was compressor. It seem it will not work longer as about 5 years. To buy another one and repair was expensive. I have now new fridge similar to this but I hav for compressor 10 years waranty.
Mar 29, 2014 | Samsung RL41WGIH Bottom Freezer...
I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Aug 12, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
I can't get the light cover open to replace light bulb , is there a special way to do so?
Hi!!
Yes, there is a special and different way to replace the light bulbs, there are 3 light bulbs on your fridge, besides the dispenser lights. Click on the following link to get an Owners Manual for your unit, look on page 15 for light bulb replacement. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60412-1.pdf
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 16, 2011 | GE GSF25XGR Side by Side Refrigerator
The light in my fridge compartment went out. Can I buy any bulb to replace it or is it a special one?
They are not particularly special just small and low wattage.
If you remove the old one you can get the wattage details from it.
Often fridge bulbs are screw in thread.
Dec 20, 2010 | Electrolux FPUI1888 Top Freezer...
Lights bulbs burned out....replaced them with new ones, but they will not work????
Fridges and stoves have a special 40 watt bulb that is only for them as it withstands high heat and low cold temperatures. Any Canadian Tire or Home Depot or Rona carry them but ask for it specifically.
Nov 01, 2010 | Refrigerators
Can I replace the LED light in my refrigerator?
I am not aware of any special tools or proceedues require to replace a LED light bulb, however,...... LED bulbs are generally very long life bulbs (read est. 10 year life, minimum). There is at least one manufacturer which has had some issues with their LED bulbs, and it is possible that GE may have outsourced some manufacturing, so we can not rule out a bad LED, however, it is actually more likely that you have a problem with the board or a switch, in which case the service tech will have to find out why your LED is not lighting.
Oct 16, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Light inside does not work, even after putting in a new bulb. Could it be a bad door switch. If so, can I replace it. How do I replace it?
It probably is a bad switch, in most firdge the switch is installe in a pop-lock construction. maybe the spring inside the switch is busted. Also please check the bulb you bought. it should be rated for refrigerators or else it wont work.
May 08, 2009 | Refrigerators
Refrigerators Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
