I have a Technics RS-TR979, double cassette deck with autoreverse. Problem: pressing a button results a wrong action sometimes. For example, pressing "reverse Play" may result a "Record" action, pressing "Stop" can activate "Fast forward" function, pressing "Rewind" activates "Play" etc. This effect is present right after switching the unit on, and is more noticeable on Deck 1 and less on Deck 2. After one hour of unit using, the effect almost disappears, but returns next time of using the deck. The deck is used very rare, once in 2-3 months. If the problem is with some part(s) of the deck, I'll be grateful for naming these parts. Thanks in advance.
5 Suggested Answers
  • 189 Answers
SOURCE: connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Posted on Jan 09, 2008
robotek
  • 1512 Answers
SOURCE: Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Posted on Jan 26, 2008
caroldon
  • 17129 Answers
SOURCE: How to replace drive belts on Technics dual
First of all you will need some mechanical mind to open out the set. The tape mechanism has to be removed and the connections should be noted and removed. If the old belt is already in the mechansim then you will not have any issue with the direction of the belt to go around the capstan flywheel. If you have alreaddy obtained the correct belt then carefully open the back of the mechanism to remove and reset the new belt. When replacing check for the free running of the capstan if not use a small drop of oil to free. If the belt was not there then wind from the motor to the second flywheel after running it around the first flywheel to drag it along so that when the motor turns you have the flywheels turning freely. reset the back plate using a thin probe type tool to hold the belt and release to the motor. For a first time it may be a bit difficult but try again. Hope you get this right. Good day
Posted on Jul 20, 2010
SOURCE: I have a Technics RS CH770 twin cassette deck
I have some to sell if you still needs?
gavinmart@hotmail.com
Posted on Aug 16, 2010
How to tape from one deck to another?
Press the Dubbing A to B button. Put your blank tape in deck B. Press REC/PAUSE on deck B. Press Play on deck A
May 21, 2014 | Technics RS-TR272 Single Cassette Deck
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
207 people viewed this question
 Grubhead
Grubhead
