Question about D-Link GigaExpress DGS-1005D 5-Port Gigabit Ethernet Switch (DGS1005DB)
How to reset dgs 1005d switch with an unknown password?
5 Suggested Answers
  • 10 Answers
SOURCE: tcp ports
it depends on the type of internet service you have if it is cable internet most cable modems can act as a gateway for conecting multiple computers but the cable company needs to activate that feature on the modem.
Posted on Jan 04, 2008
toac990
  • 838 Answers
SOURCE: re:D-Link dgs-1005d mounting plates
For this as per my knowledge there are no extra mounting plates comming commercially. But itself having some mounting tools such as wall plug, screw etc. in it's package....and for permanent installation if you need it very much you can order such thing in turning workshop...but try to use it in friendly environment....because those are heat and hazard sensitive for heavy duty.....All the best.
Posted on Oct 21, 2009
bjpattonesq
  • 52 Answers
SOURCE: Lost passord dlink dgs 3224tgr switch
here is the link from Dlink support for your switch:
http://www.dlink.com/products/?pid=DGS-3224TGR
Posted on Nov 06, 2009
  • 4350 Answers
SOURCE: I got this switch DGS-3224TGR
Yes, you can reset the unit, but I suggest that you RESET to YOUR specs.
Get the install program from D-Link, for free, but below are the highlights of what I think is important to set:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Posted on Jul 07, 2011
Hi, I am not sure what my user name or password is for my router, when i past in my default getaway IP. I have DGS-1005G D-Link pliz help me
User name : admin
Password : admin
or
username : admin
password : leave it blank
if still not, you can reset the router to its factory settings. You can do that by pressing and holding the small reset button at the back of the router. You will need to use a pin to do that. Usually, the reset button has a red circle drawing on it. Just press and hold it for 10 seconds while the power is on. You will notice that the lights will flicker including the power light. It will turn red. Once done, just wait for the router to boot then access the GUI and use the login that I have provided. You should be good to go.
Apr 20, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Well my friend found me a d-link router and all it came with was a power cord and the router itself and when i searched up the name for it i got D-Link DGS-1005D 5-Port Gigabit Switch. i am not sure how to...
you can find all the data you need in the following PDF manual
ftp://ftp.dlink.de/dgs/dgs-1005d/documentation/DGS-1005D_man_en_v2-01.pdf
hope this helps.
Dec 28, 2010 | Computers & Internet
Hello, Got a D-Link 1005D 5x100 Im having 2 computeres atm, but i cna only get one to work. When i plug the internet cables from the computers to the D-link router, only one can work, please...
Your D-Link is a "switch", not a "router".
So, every computer that you connect will require a _UNIQUE_ IP-address.
However, your account with your Internet Service Provider is only granting you *ONE* IP-address.
Upgrade your account to pay a few dollars more per month, to get additional IP-address(es).
Buy a D-Link Router, for under $50, and connect both computers to the 'LAN' ports,
and connect the 'WAN' port to your cable-modem (or DSL-modem).
Dec 08, 2010 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Hi, it seems as it get stuck, stop all trafic. After disconnection and reconnect it works again, Any ideas?? Lights flckers as if trafic is going on /Steen
Take a look at the location you have it placed in. These off the shelf solutions are nice quick fixes but they over heat easily. This causes the firmware to crash. So you reset 'em and all is well again. Until it overheats again. Check out Ubiquiti's bullet router. I've got one running 100 computers and I havn't had an issue with it yet.
Nov 11, 2009 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Re:D-Link dgs-1005d mounting plates
Oct 20, 2009 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Connecting xbox live to my d link 1005d
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Adam
Oct 26, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
D link des-1005d
do a factory reset. see if that helps. Check IP mapping, make sure the two PCs are on different IPs
Aug 14, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Tcp ports
Jan 03, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
D-Link GigaExpress DGS-1005D 5-Port Gigabit Ethernet Switch (DGS1005DB) Logo
783 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
