Question about Linksys NSS4000
Loosing users permissions
The NSS4000 as lost the permissions twice, what can be hapenning?
  • 142 Answers
Hey You can refer to thin link here :
You can check the settings and if it is again again losing the settings then there might be a possibilty that the firmware of Nss4000 has gone faulty or is corrupted.
You will have to upgrade it through the CD provided to you or best will be to contact Linksys and they will be able to give you the exact information...
Posted on Jun 03, 2008
Some users can't view uploaded documents. They seem to have all the same settings as others. Can't find a setting that differs.
To look about Root user group and others rwx read write and execute permissions if this applicable then
BUT !!! Microsoft has an other way with registery settings especially in REGEDIT what can give a problem by users who have administrator settings but have had special settings or utilitys or malware load without knowing and much more problems
If its not have a problem thats hard to find , then try first the easy utility windowsrepair from and or privazer, use allways first the default settings and make allways a complete backup (Macrium Reflect Free ) after heaving a full backup image on another drive safe then use windows repair first and if the problem was repaired but other problems are come after the repair from registry after repair and some other functions are lost do not a systemrestore first but only the registry restore first. that will be give the right permissions back on default setting. and if that is have also problems the best is to do a ( repair to remove some hard malware and or viruses , but only to play with it only after heaving made a full backup before for the safety to do not loose data.
Nov 29, 2016 | Computers & Internet
I get an error code 0x80070522 what does this and how do i fix it?
Thank you for choosing FixYa!.
"Error 0x80070522: A required privilege is not held by the client" is this what you're getting?
Trying the solution below MIGHT delete some files on your drive C: which, of course, I don't want to happen. Whatever you have on the hard drive at the moment, kindly BACK THEM UP. This happened to me twice that I cannot rename, or write anything on the drive C:. This is what I did and it fixed the problem. Unfortunately, I lost some of my files. It happened again, and this time, before I did it; I backed up my files to be sure nothing will be lost this time. Guess what, nothing changed but all permissions granted and an issue resolution. I really can't figure out what the reason is behind that data loss but then again, before you try it, BACK UP BACK UP BACK UP.
This error might occur due to permissions that are not set properly for the C Drive.
Make sure that you are logged in as Administrator or the Primary account or profile.
To take ownership of C Drive, follow these steps:
1. Right-click the C Drive and then click Properties.
2. Click the Security tab.
3. Click Advanced, and then click the Owner tab.
4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group.
5. Click on Edit and then put a check mark against "Replace all existing inheritable permissions on all descendants with inheritable permissions from this object".
6. Click OK, and then click Yes when you receive the following message:
This will replace explicitly defined permissions on all descendants of this object with inheritable permissions from C-Drive (C:).
Do you wish to continue?
7. Once the permissions are replaced, click on Ok.
8. Check if you are able to copy, paste or delete any documents now.
If the above steps fail then you may also want to disable UAC and check if that helps.
1. Click Start, type msconfig in the start search box, and then press Enter.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
2. Click the Tools tab.
3. Click Disable UAC and then click Launch.
4. A command window appears, and shortly thereafter, a notification bubble appears informing you that UAC is disabled.
5. Click Ok and restart your computer to apply the change.
Please let us know if it helps. It should solve the issue. Thank you for choosing FixYa!
Apr 15, 2011 | Dell Computers & Internet
I already asked aquestion but solution didn't work. I got a computerfrom my sister-n-law and everything is setup with a user name and I tried to delete user name and now com says............. User's...
Boot into recovery mode from GRUB menu, at the prompt, change user password again to something easy to remember.
passwd user
Then, change the ownership/permission of /home/user/.dmrc to you won't get that error/ignore message the next time you log in.
chown user:user /home/user/.dmrc
chmod 644 /home/user/.dmrc
Now reboot.
shutdown -r now
Mar 05, 2011 | MSI Wind U100-030US Laptop
the default ip is
user name is admin and password is password
Nov 16, 2010 | Linksys NSS4000
Hi there, I have brand new linksys NSS4000 and i am not able to access the box to do the basic confiigurations, so anybody know the default ip address or how can i access the box?
There are a variety of ways to display the NSS Login window.
•Open the Web browser on your computer: In the Address field, enter "http://NAS<MAC address>" (For example, "http://NAS0018F804E44C".)
•Browse for the NSS from the My Network Places window.
•Select the NSS to a network drive from a mapped network drive.
The NSS Login window appears:
Also please follow the below link for manual it will help you to setup
let me know if this worked for you
Dec 01, 2009 | Linksys NSS4000
MS WIN2K3 Server doesnot find NSS4000 shares
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
Mar 12, 2009 | Linksys NSS4000
Do not allow to cange password
If you have more than 2 user accounts login to the other one and then try changing the password.This will fix the issue.let me know the result.
Feb 10, 2009 | Microsoft Windows XP Professional for PC
I keep getting this error message when I try and upload a page in DreamWeaver- or change an existing page. The pages are "locked" but I have never locked them and they have never been locked. I...
Try this:
To change permissions for a disk, folder, or file:
  1. Select the item you want to set permissions for, then choose File > Get Info and click Ownership & Permissions, if necessary. If you want to set permissions for multiple items at once, select them, and as you hold down the Control key choose File > Get Summary Info.
  2. Choose a permission for yourself from the pop-up menu. If the menu is dimmed, you don't have permission to change this setting.
  3. To change permissions for the owner, group, or others, click Detail. If necessary, click the lock icon and, when prompted, enter the name and password of an administrator user of your computer.
  4. Choose permissions for each type of user from the Access pop-up menus.
Nov 30, 2008 | Computers & Internet
NSS4000 dosen't boot
your english is not bad to to start with!
and the possible solution to your problem is just ask the administrator to help you out,dont try to do it yourself cause sometimes problem gets worsen!
Dec 05, 2007 | Linksys NSS4000
Problem with exec 11d and NSS4000
Can you create folders by hand from the same account that the backupexec services are running under? if not you have to change the permissions.
Aug 26, 2007 | Linksys NSS4000
Linksys NSS4000 Logo
270 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
