Question about Microwave Ovens
Several of the numbers do not respond when pushed. It started with the 3 but it has progressed until 3 or 4 other numbers do not respond. Makes it impossible to set the time for cooking, to set the clock or the timer. This microwave's serial number is 380968 and it was manufactured 12/2003. Thank you.
  • mlh68 Oct 16, 2010
    I don't know what panel you are referring to.
    No. I have no idea what panel is being referred to.
  • 712 Answers
This might be a contact error. It can be caused due to dust in between wirings. Open up the panel and clean carefully. Also, replace the codes with new ones, if necessary.
Posted on Oct 16, 2010
How do I change temp and time while food is cooking?
all is explained in the user manual
if you have just put food in the even and pressed the start several times to get a number of minutes to cook but want to increase that time just press start again the number of times that you want the cook time to increase
for example :-
you put a frozen pie in the oven and your start operates in 30 second increments and you have pushed it 3 times and it starts cooking-BUT - you read the cooking instructions and it says cook for 4 minutes, just press the start another 3 times while it is cooking
the new cook time will show on the display
Dec 30, 2016 | Microwave Ovens
When can I order a conical spring for the trigger?
Keep calling the company, somebody has to know where they can get you that 'spring', after all it's the customer service that makes a good company great ! Can you make one for a paper clip or something else, maybe a spring on a clothespin? Keep thinking, you'll come up with something.
Nov 06, 2014 | Microwave Ovens
Microwave turns on but keypad doesn't respond.
If it's brand new it should easily be returned to the manufacturer (Or retail outlet) So dont worry, Just take it back tell them your problem,. They'll probably be happy to help, This is a situation where you can do little if anything and are probably facing a defective product
Dec 02, 2013 | Bosch 800 HMB80 1000 Watts Microwave Oven
Most push buttons do not respond when pushed. only 4, 9,start, hold warm and reset work consistant. 7 is intermittent thank you
Unfortunately the whole keypad must be replaced in order to get it fully functional again, and you would be wise to inquire the cost involved before you decide to have it repaired.
Mar 29, 2011 | Microwave Ovens
HOW TO SET CLOCK
1. push the clock button 2. display should be blinking. 3. then push 3, then 0, and 0 again (this is for 3:00) 4. then push the clock button again, and it should be set     again. 5. sometimes, by doing just the first 3 steps and letting     it be until the blinking stops, is another way. But             most likely, you'll need to follow through to step 4
Mar 28, 2010 | Belling BIM60 Microwave Oven
Keypad does not always work
HI. you will need to replace this malfunctioning key pad asap. this will require you to disassemble the unit, in order to reach the actual touch pad board. It is not an easy task, and i recommend a professional tech, if possible.
Aug 26, 2009 | Maytag MMC5000 Microwave Oven
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
Giving -F3- display and beeping 3 times, does not respond
If that doesn't work, you have a shorted / failed membrane keypad.
Until it is repaired, please leave it unplugged or leave the door open.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jan 11, 2009 | GE JVM1850 1000 Watts Microwave Oven
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
Sep 21, 2006 | Sharp R-230 Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
