Question about Lexmark T644 Laser Printer
Paper jam the menu screen shows a paper jam it says to open rear duplex door and remove print media, we have torn the entire thing apart and there is no paper anywhere
  • Anonymous Jul 17, 2008
    Says paper jam, open rear duplex door. Everything is clear. What do we do?
    Problem Solver:
Probably one of the sensors on the fuser is not working correctly. There are two sensors on the back of the fuser that move when the paper exits the fuser. Remove the back of the printer when the printer says there is a jam and move the sensors to see if the error goes away. If so you may have to replace the fuser unless you can just replace the defective sensor.
Roger
Posted on Jun 17, 2009
I have a paper jam at the back of my printer, where do i open it
Hopefully this will help you. Good luck !
Causes of jams
NOTE If you are experiencing jams in the duplex paper path, make sure that the duplex-tray
lever is set to the correct media size for your country/region. Open the duplex-paper-path door
and look at the embossed arrow on the lever. Make sure that it points to the media size for your
country/region. If the size needs to be changed, push the lever all the way in for duplex printing
on letter- and legal-size media, or pull it all the way out for duplex printing on A4-size media.
A4
LTR,
LGL
A4
LTR,
LGL
Occasionally, paper or other print media can become jammed during a print job. Some causes include
the following events:
? The print media that is being used does not meet HP specifications.
? The media is damaged or has objects attached to it, such as staples or paper clips.
? The environment in which the print media was stored is too humid or too dry.
? The input trays are loaded incorrectly or overfilled, or the media guides are not set correctly.
? Too many sheets have accumulated in an output area, or sheets are blocking an output area.
? Media is added to or removed from an input tray during a print job or an input tray is removed from
the all-in-one during a print job.
? The cartridge door is opened during a print job.
ENWW
Mar 13, 2015 | HP LaserJet 3300 All-In-One Printer
HP 4215xi all in one, continues to give the error paper jam, there is no paper jam. I have cleaned all sensors, rollers etc. I have tried a partial and full reset. Any ideas?
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 2: Removing the rear access door
Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  1. From the rear access door opening, remove the jammed paper.
  2. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  3. Reinstall the rear access door.
  4. Reconnect the power cord to the unit and turn the unit on.
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Goodluck..
Mar 17, 2008 | Computers & Internet
My printer carriage has jammed.
To resolve the issue, you can try each solution in this document in the order presented.MPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware functions correctly. To print a self-test report, use the steps in the following table:Load plain white paper into the input tray.Press Setup on the product control panel.Press the right arrow ( ) to select Print Report , and then press OK .Press the right arrow ( ) to select Self-Test Report , and then press OK . The self-test report prints.Solution one: Turn the product off and on again Follow these steps to turn the product off and then on again to reset the printing mechanism Press the Power button to turn off the product. If the product does not turn off, continue to the next solution.Wait 60 seconds.Press the Power button to turn on the product NOTE:The product might go through a warm-up period. The product lights might flash and the carriage might move. Wait until the warm-up period finishes before you proceed. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution.Solution two: Clear any paper jam Follow these steps to clear any paper jam.Step two: Clear the jam from the rear of the product Use one of the following methods to clear the paper jam from the rear of the product. If your product has a two-sided printing accessory (duplexer), skip to Method two.Method one: Clear the jam from the rear access door Press the Power button ( ) to turn off the product, if it is not already off.Disconnect the USB cable from the rear of the product.Disconnect the power cord from the rear of the product.Remove the rear access door: Press the tab on the left side of the door inward, and then pull the door out.Figure 1: Remove the rear access door ently remove any jammed paper from the rollers.CAUTION:If the paper tears while you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.Figure 2: Remove torn pieces of paper from the rollers Reattach the rear access door. Gently push the door forward until it snaps into place.Method two: Clear the jam from the two-sided printing accessory (duplexer) Press the Power button ( ) to turn off the product Disconnect the USB cable from the rear of the product.Disconnect the power cord from the rear of the product.Remove the two-sided printing accessory (duplexer) from the rear of the product: Press the buttons on each side of the duplexer, and then pull it toward you. Figure 3: Remove the two-sided printing accessory Gently pull the jammed paper out of the rollers.CAUTION:If the paper tears while you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.Figure 4: Remove torn pieces of paper from the rollersIf you do not see jammed paper in the rear access area, push the latch on the top of the duplexer, and then lower its cover.Figure 5: Open the duplexer - Latch on top of the duplexer Duplexer cover Remove any jammed paper from inside the duplexer.Close the duplexer cover, and then reinsert the duplexer into the rear access area of the product. Figure 6: Reinsert the duplexer Push the duplexer inward until it clicks into place.Step three: Clear the jam from the front of the product If you cannot remove the paper jam from the rear of the product, follow these steps to remove the paper jam from the front.Open the cartridge access door.Figure 7: Open the cartridge access door NOTE:The carriage should be on the right side of the product, out of view. If it is on the left side, close the cartridge access door, and then turn on the product. Unplug the power cord from the wall outlet, and then open the cartridge access door again.Look for any pieces of paper or other debris inside the cartridge access area.Gently pull the paper out of the rollers.CAUTION:Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.Close the cartridge access door.Figure 8: Close the cartridge access door Reconnect the USB cable to the rear of the product.Reconnect the power cord to the rear of the product.plug the power cord back into the electrical outlet. Press the Power button ( ) to turn on the product. Reload paper in the input tray.try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.If the issue persists , continue with the next solution.If the self-test report does not print , continue with the next solution.Solution three: Make sure the carriage moves freely Use the following steps to make sure the carriage moves freely.Press the Power button ( ) to turn on the product, if it is not already on.Open the artridge access door.Figure 9: Open the cartridge access door Without turning off the product, disconnect the power cord from the rear of the product.WARNING:You must disconnect the power cord to move parts by hand without the risk of an electrical shock.unplug the power cord from the wall outlet.Look inside the product to see where the carriage is stuck, and then check for any torn paper or other objects that might restrict the movement of the carriage.NOTE:You might need a flashlight to illuminate areas inside the product Figure 10: Use a flashlight to see inside the product Remove any loose paper or obstructions you find.Figure 11: Example of obstruction in carriage access area Reach inside the product through the cartridge access door, and then manually move the carriage. You might have to reach through the paper output tray to access the carriage.If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.Make sure the carriage moves freely across the width of the product by gently pushing the carriage to the left, and then to the right.Close the cartridge access door.Figure 12: Close the cartridge access door. Reconnect the power cord to the rear of the product.Plug the power cord into the wall outlet. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. four: Remove and reinstall the cartridges Improper placement or installation of the cartridges can cause the product to indicate a carriage jam error.
Oct 12, 2011 | HP Officejet 6500 Wireless All-in-One...
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
All in one printer displays clear paper jam then press ok, but no paper jam can be found on printer. hp photosmart c5380 all in one.
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert HP technician to mend it.
Sep 25, 2010 | HP Photosmart C5380 All-In-One Laser...
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Lexmark T644 Laser Printer Logo
795 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
