Question about Video Cameras
Sony Video Camera Recorder CCD-F500E
I have had this camcorder for many years. When I tried to use it today after several years, the cassette holder door would not open when pushing the eject button. Can you advise me on this please.
  • saggie Jun 03, 2008
    Hi Dan
    Thanks for your reply. I can hear the motor action and it is connected to the AC. The viewfinder is lighting up when in camera mode. The camcorder hasn't been used for several years - could this be the problem?
    Saggie
  • Anonymous May 09, 2009
    Like wise saggie
    After meny years the camera has decided to go bust...
    When I push the eject button the latch comes half way up and then decides to go all the way back down???
    I have pulled the camera appart and found no loose screws in the motor. What is my next step to adress the problem at hand?
    Cheers Paul
  • 4,234 Answers
Assuming that the model is the F500E, I need to know if you hear any motor action at all. Also, have you tried with the changer connected directly to the camera (power from AC rather than battery)? Do you have the viewfinder lighting up when in camera mode?
Thanks,
Dan
Posted on Jun 03, 2008
  • ABRsvcs Jun 03, 2008
    I have seen loose screws get caught in the motor area preventing the heads from spinning. Unfortunately these are not the easiest cameras to work on. I would not suggest that you tackle this unless youhave done cameras in the past. This should be a simple "rebuild" of the camera and shouldn't cost more than the minimum labor cost for cameras.
    Dan
My camcorder keep saying reinsert cassette
Try reinserting a Brand new Cassette . If this dos`nt work take the battery out over night reinsert the battery with the Brand new cassette in it .if you used the recorder to play very much footage as a viewer it has over heated it . the sensor that sense`s a cassette is just a little out of place with a little skill and if you know what you are looking for you can put this back in possition!
Aug 30, 2011 | Sony Hi8 CCD-TRV138 Camcorder
Error 04: unit in safeguard mode, eject and reinsert tape. However, after I opened the cassette holder cover, the cassette holder didn't automatically open, and I can't get the tape out. I tried taking...
hi
i am dammika
from sri lanka
i have a jvc handy cam
but it broken display ribbon
i want by it in sri lanka
how can i get
pls send me a sms 0094778280849
thanks u
Apr 26, 2011 | JVC Video Cameras
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Sony video camera DCR-HC-26. Bought Camcorder
I would take it back to Radio Shack and demand your money back. I would do some research on sony's website and find the right cleaner for you camera.
Dec 11, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Manual for camcorder/sony-HI8 camcorder-ccd-trv68eE9EVT.HTML SONY CCD-TRV68 HANDYCAM
Download the manual from:
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Please rate this solution as it helps us in helping you and others like you.
Sep 08, 2009 | Sony Video Cameras
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony camcorder
you might want to try this place alamocameraservice.com
Nov 12, 2007 | Sony Handycam CCD-TRV11 8mm Analog...
Cassette load issue
reel table on the right ( take - up ) if has low tension ? will slow down or stop , giving reinsert error : stretching spring ( inside reel table ) will fix problem , as well as to order and replace reel table .
Aug 07, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
Video Cameras Logo
1,156 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
