Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint washer/dryer wd860p is spinning on drying cycle but there is no heat. What could this be ? many thanks
    Problem Solver:
  • 9 Answers
The heat coil may be damaged. A few years ago I took apart my dryer and saw that the coil resistance wire (glows red when a current is passed thru it) was broken. I was able to buy the part and put it in and it worked after that. If I had to do it again, I'd just call a repair guy.
Posted on Oct 16, 2010
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
Hi i have a hotpoint aquarius wd440 14000 spin i have flashing lights on the on off and on the drying heat. It is a washer dryer .but I never use the dryer. can somebody please tell me what's
I believe your issue is a blocked/clogged water drain. If your unit appears to drain all of the water at the end of the cycle, you may just need to clean your filter. The machine can sense when it takes too long to drain and it flashes those particular lights to let you know what the problem is.
Dec 22, 2014 | Hotpoint Washing Machines
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
I have a Hotpoint WD62 which intermittently trips the house main circuit breaker. Looking at other blogs I am lead to believe it could be the suppressor. Is this likely? And as also suggested elsewhere can...
It really depends upon at what point it trips the breaker. During washing, spinning, drying? If it is during drying don't use that cycle- it could be the dryer heating element. A supressor is normally used on the motor to supress the effect of sparking from the commutator/brushes so I doubt very much that it is that- it would probably trip immediately all the time. It could, however, be the motor itself which is malfunctioning particularly if the tripping happens around spin time. I do think you should call in an engineer, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 07, 2011 | Hotpoint Ultima WD72 Front Load...
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Washing Machine not spinning
Bring your sample to appliances store let them chech if their available.
Check the heat sensor detach one line test the continuity both terminal if open replace it.
Jan 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
87 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
