Question about Samsung WF337AA Front Load Washer
NEW SAMSUNG WASHER WONT DRAIN.
SAMSUNG WF337AA BRAND NEW BUT WILL NOT DRAIN WATER
  • Anonymous Mar 26, 2009
    I dont have a debris filter like this
  • dvoncannon3 Apr 22, 2009
    We were washing clothes and left our home. When we returned, the machine was humming a solid, steady hum, but not too loud. There were not any errors on the display but it had clearly not drained and was "stuck" in the drain/spin cycle.
    Problem Solver:
  • 19 Answers
I had this problem and after emptying I still had it.
i ended up taking the back off, removing the pump and discovered hair was stopping the impeller fan from moving.
after a clean it's perfect.
very fiddly job but easier if you lean the machine over slightly.
Also samsung after care for the same things going wrong is terrible I saved a small fortune doing this as samsung wanted nearly 100 just to take a look!
Nick
Posted on Oct 18, 2014
  • 7 Answers
Try clean debris filter locate in front of the machine.
Posted on Jun 23, 2008
I have a samsung WF393BTPAWR/A2 that will not spin all water out
There is most likely a blockage prenting all the water from draining out by the time the spin cycle starts. check drain hose and filter if there is one.
Oct 03, 2014 | Samsung WF337AA Front Load Washer
Samsung washer wa5451an wont drain
Had a similar problem. Turned out the pump impeller got jammed in a broken off zipper pull tab. The pump motor still ran and the belt was slipping. If you decect a burned rubber odour, then that is your problem.
J.I.
Mar 14, 2014 | Samsung WF337AA Front Load Washer
Samsung washer wont spin
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Check this link for tips;
Jun 28, 2012 | Samsung WF337AA Front Load Washer
I have a samsung vrt washer. I have a load of clothes in and it says that it will not drain and to check the filter. I opened the hole on th ebottom of the washer and water is coming out everywhere HELP
use a wet dry shop vac and attach it to the end of the drain hose to remove most of the water then as you unscreww the cap again you will have a small amount of water coming out just keep using you shop vac until all the water is gone then checdk the drain pump
Nov 03, 2010 | Samsung WF337AA Front Load Washer
Samsung washer front load willnot rinse - no water coming out of hose to drain. E2 shows up
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
May 31, 2010 | Samsung WF337AA Front Load Washer
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
How to drain water after laundry?
at the bottom of the washer is instructions on how to drain the water inside the washer. A small hose is contained at the bottom right hand corner with a white plug (you need to pull on it hard). Once you remove the plug from the small drain hose it will drain all the washer water.
Before you do all this make sure you disconnect the electrical wire or turn off the breaker switch to the washer machine.
Dec 22, 2008 | Samsung WF337AA Front Load Washer
Same thing Happened to me I found that there was a small coin caught up in the filter..
Aug 24, 2008 | Washing Machines
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
1,663 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
