Question about Vacuums
Why does my sansa turn off by its self and why does it take for ever to turn back on and the screen goes black when iam listening to music and it takes for ever for the screen to come back
  • 2,418 Answers
Go to the Sansa support site, I can't help you very much, you did not give your model number. Check out the FAQ's on your player..http://kb.sandisk.com/app/home
Posted on Oct 16, 2010
How do i fix my hoover windtunnel if self propel is stuck on ?
There is a cable that goes from the handle to the base, the cable or the plastic piece it attaches to at the base of the vacuum may me broken.
Jan 31, 2015 | Hoover Vacuums
Well The Music Is Blurry So I Cant Hear Anything
Are you listening to Blur? Try a different band, maybe Oasis. Vacuum cleaners don't tend to be too good for music
Jan 27, 2011 | Vacuums
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
My lux 7000 has a new bag but when i start to use it with the power unit or without the unit shut's it self off i can reset the lites or the motor if you will by clicking the on off switch 4or 5 times...
Have you replace the afterfilter? It may also cause this if rather dirty. It's located under the tool caddy/air diffuser on the back half of the machine.
Try this: Disconnect hose, turn on vacuum. Does it continue running? If so, place palm of hand over intake. Does it shut off? If so, it's probably a broken or worn out "control valve assembly" (CVA). Or a tube connecting to it could be clogged and simply needs cleaned out. This is very common in vacuums that have had generic or "made to fit" bags used in them. Either way, this is a job for Supertech.
Take your vacuum to a nearby Aerus Electrolux authorized store and have the service tech check it out, provide an estimate for repair, and then repair it. It's a good idea to have the interior cleaned at this time, and doesn't cost a lot more. It will get rid of the dust in and around the motor that could shorten the life of the motor.
To locate a store near you, follow the directions on the following site:
http://www.aerushome.com/storelocator/
Oct 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
The belt p/n 0100623 broke - need instructions on how to replace it - we have Bissell ProHeat Powersteamer
I just replaced mine last night. 1) take off the top belt cover. 2) take the water and cleaning solution tanks out then lay the unit on the side so the bottom of the cleaner is facing you (water and solution may leak out so you might want to do this on an old towel). 3) On the same side of the machine as the belt cover but on the bottom you'll see an orange piece (at least it is on mine) that is held in with one philips screw. Take the screw out then slide the orange plastic piece out (might need a pliers to help). 4) there is a black cover over the brush belt that has a tab on it. Pull on the tab and the brush roller on that side will come out of its place. 5) You'll see a cogged belt that drives the brushes. Just slip that off the drive on the machine. You don't need to take it out completely - just off the drive. 6) Slip the new belt (p/n 0100623) in and on to drive. It goes "inside" of where the cogged belt goes. 7) Slip the cogged brush belt back on. 8) push the brush roller and black belt cover back into position. 9) slide the orange plastic piece in place (make sure the belt cover is held in place by it) and screw it back on. 10) flip the cleaner so it is on its wheels again. 11) pull the new belt over the metal drive and manually get it kind of centered. Make sure it isn't touching any protruding plastic. 12) plug in the cleaner and quickly turn it on and off while looking at the new belt. You should see it self center. 13) put the top belt cover back on 14) insert water and cleaner tanks. 15) get to work.
It'll take less than 10 minutes to make this fix (less than 5 probably).
Jun 19, 2008 | Bissell Vacuums
Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Oct 28, 2007 | Hoover Vacuums
Self Propelled Feature Has Stopped Working
Does the brush roll turn when it it is on the carpet? The flat belts should be changed often, they stretch and won't turn the brush roll. When you pull back on the handle, does it feel loose or does it feel like you are pulling a cable. It you tilt the handle back, then look down on the right, there is a cable, does it look ok and attached to a nlack plastic part, if not then the actuator is broken. Do the 2 knobs on the nozzle slide back and forth, if not, then the slide may be broken. You may have to take off the top cover and inspect it.
Nov 16, 2006 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
