Question about Kenmore 74602 Gas Dryer
Dryer is running but gas won't light up. - Kenmore 74602 Gas Dryer
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
Amana Gas dryer runs but ingniter won't glow and gas valve won't open
That means no power is getting to the gas assembly. The number one suspect would be the fuse which mounts directly on the blower housing right next to the control thermostat.
AMANA MANUAL FOR DRYERS
My Home movies
Sep 08, 2012 | Amana Dryers
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
My dryer is running but not drying. It doesn't blow hot air. Is there a pilot to light on the dryer, and if so where?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 14, 2010 | Kenmore 93142 Gas Dryer
I NEED TO KNOW HOW TO LIGHT THE PILOT TO MY GAS DRYER
Hi, Most dryers today use a hot surface ignitor to light them...yours probably went bad... If you have a gas dryer2_bing.gif.
heatman101
Aug 11, 2010 | Maytag Atlantis MDG8600AW Gas Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Gas dryer wont light
heatman101
May 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do you light the pilot light?
heatman101
May 25, 2010 | Kenmore 700 6972 Dryer
How to light it it is not hot does it have a
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
heatman101
May 05, 2010 | Kenmore 73952 Gas Dryer
Kenmore 74602 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
