Question about Samsung WF337AA Front Load Washer
Kenmore 90 washer won't drain
Kenmore 90, five years old, model number 110.22922100 won't drain. Is it the pump or something more serious? JUST PURCHASED SAMSUNG FRONT LOAD WASHER. WF337AAG. RUNS FINE UNTIL IT IS TIME TO DRAIN. WATER WILL NOT DRAIN AND MACHINE DOES NOT DO ANYTHING
How do I operate it? which program should i use for regular laundry?
Posted on Jul 08, 2010
    Genius:
  • 1,028 Answers
Ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Posted on Jun 04, 2008
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore 90 series heavy duty washer that is leaking water all over my floor enough to soak up a couple of towels. What can this be and how do I fix? thank you.
could have a cracked water pump or the pipe that the drain line drains into is backing up.one other thing it could be is bad tub seals,the water will leak from the bottom middle of the tub but most likely it will be the pump,this is an easy fix,pop off the two clamps that hold the pump on and with a pair of plyers remove the two clamps on the hoses,make sure you put down a couple of bath towels to catch water that's still in the hoses,let me know how you make out,next time send model number,one of the most common pumps for your machine is 3363394 but check it with the part number on the old pump and give the parts store the correct model number.good luck
Jul 14, 2010 | Kenmore 22422 Top Load Washer
Washer won't drain
could be your pump ,something stuck in your pump, motor could be bad on the reversing side
Feb 13, 2010 | Kenmore Washing Machines
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Check first drain line or water pump to see if they are clogged.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Jan 14, 2008 | Washing Machines
Put a spin on it
vzone, you don't have a belt on this model. After the agitation, the washer should go into a nuetral drain for about 90 seconds getting rid of most of the water before spinning. See if yours is doing this. If it doesn't, the gearcase lost it's nuetral drain. The gearcase has a five year warranty on it, part only. If it's ok, the next thing I would do is check the drain pump itself, see if it has a bunch of junk wrapped up in the impeller restricting the flow. The pump comes off easy. Two clips and two clamps. Check the photo, Catriver..post back.
Apr 29, 2007 | Kenmore 23822 Top Load Washer
Samsung WF337AA Front Load Washer Logo
682 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
