Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Homelite trimmer will not start. When running before, it had to be in full choke. It stalled when put in half choke or run mode.
  • Homelite Master
  • 7,482 Answers
Check your fuel filter if you have one, and also make sure you are using fresh fuel and oil mix...to the right mixture and not too much oil.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 16, 2010
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
Homelite very hard starting prime 10X full choke model UT32651
Make sure your fuel mix is fresh and of the right gas-oil ratio. Today's pump gas has Ethanol mixed with the gas and can go bad in as little as 30 days. this stuff is terrible to run in small 2 cycle engines. A lot of loggers I know buy Ethanol free gas for their saws. Also do not ever use starting fluid to start a 2 cycle engine ! What happens is the Either washes the cylinder wall of oil and now you have a scored piston and/or cylinder
Apr 03, 2014 | Homelite Garden
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
Stalls out at full throttle
Has the air filter been removed, damaged, or the airbox not seated propelry on the carbs neck, this would cause it to run lean hence requiring the choke to be in operation all the time. Have you tried fresh fuel?? This goes stale after a while. I hope this is helpful, Ian
Jul 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Engine run @ half choke but will not run in run position
It's starving for fuel. What is it? Sounds like the jets are plugged in the carb. or possibly water in the gas. Remove carb., disassemble, clean and put back together. You should get a rebuild kit for it first so you have new gaskets, etc. when you reassemble. It's a little more complex than I can put in words for you here.
Also empty and clean fuel tank too and start with fresh, clean fuel.
Mar 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
265 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
