Question about Toshiba PDR-M700 Digital Camera
SD card size
Hi, I am wanting to upgrade the SD card that comes with my Toshiba PDR-M700 to increase the length of movies I can record.
The maximum card size referred to in the manual is 512 MB.
Does this mean this is the maximum card size the camera will recognize?
Basically, what I want to know is if I buy a 4 GB card, will it work in this older camera?
Thanks
Frankie
  • fiavaimeaaea Jun 13, 2008
    Trying to upgrade from current 16MB in camera.Tried 516MB but LED Screen shows "Card Error'. Do you press any buttons to format new card? Haven't tried the 1GB yet if it works.
  • fiavaimeaaea Jun 16, 2008
    I tried mine with a 1GB and screen shows: "This Card Cannot Be Used", so I guess it only goes up to 512MB. But, you can keep asking if someone knows. Good luck.
  • 3 Answers
This camera only uses cards up to 512MB. In the back of the User Manual posted here, on about page 113, it states 512MB maximum. If a larger card is inserted, the LCD screen displays a message saying "This Card Cannot Be Used" with no explaination why.
Posted on Sep 30, 2008
    Habit-Forming:
  • 73 Answers
Regardless of other attributes (brand, High Speed, SDHC, etc.) the largest card I have successfully used with my PDR-M700 is 512MB.
Posted on Aug 31, 2008
    Problem Solver:
  • 4 Answers
This is to clarify my post about the 516MB(should be 512MB). It now works. So 512MB must be the maximum?
cheers
Posted on Jun 16, 2008
  • 3,037 Answers
It should work, when this camera came out there was probably no cards bigger than the 512 generally which is why it says that. If the 4GB doesn't work for some reason, it will still work in a newer camera later on so don't worry about wasting money on buying this.
have fun
Posted on Jun 03, 2008
    Problem Solver:
  • 15 Answers
You'd better find some local dealer and try. Newer SD cards use the new SDHC profile which is not supported by the camera. 1G and smaller cards should have no problem but even this largely depends on toshiba's programming ability. 4G and above probably would not work.
2gb sd card wont format this is a toshiba pdr-3300
Hi, is it an SD card of normal size? if so there's a little switch on the side which says protect, move this the other way to enable Formatting..
Thanks Mark
May 03, 2010 | Toshiba PDR-3300 Digital Camera
I cannot find an SD card to work I have tried a 1GB SD card and it will not work in my PDR M 500 digital camera why does it not work?
I found a press release that the PDR-M500 cameras only support SD card sizes up to 512MB.
This was from June 2003 so this camera was quite an early one.
This was quite common in the early days to restrict the maximum card size the carmera could use.
Feb 02, 2010 | Toshiba PDR-M500 Digital Camera
What kind of memory card does this camera take?
i checked specs on that camera and the maximum memory card you can use is 512mb. if you get one that size you should have no errors anymore
Feb 19, 2009 | Toshiba PDR-M700 Digital Camera
1GB SD memory card problem
Your camera is an old model and can't handle big memory card. Use only 128 or 256MB card in this model.
Aug 23, 2008 | Toshiba PDR-M700 Digital Camera
Toshiba PDR-M700
It sounds as though the drive gear is slipping... If you give up on trying to repair your camera I may want to purchase it for parts (my sister-in-law broke my LCD display)
craigdieter@sprintmail.com
Jul 29, 2008 | Toshiba PDR-M700 Digital Camera
PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Hope this helps! -Kim
Jul 15, 2008 | Toshiba PDR-3330 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Card Error Message
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Toshiba PDR-M700 Digital Camera Logo
211 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
