Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
I am a windows running computer connected to a Parkervision signalmax wr1500 router... I have internet access but my laptop (mac) cannot find the network that was previously accessible. What did I do wrong?
  • Consultant17 Oct 16, 2010
    Are you using windows XP?
  • selenay Oct 16, 2010
    yes, xp home!
    Scholar:
  • 97 Answers
If your mac is trying to connect wirelessly? If so, did you secure your wireless by disabling the broadcasting of the SSID?
If you have disabled SSID broadcasting (which is a good security measure), you will probably need to manually add the wireless network and key to get this to work.
Hope this helped! :)
Posted on Oct 17, 2010
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How do I secure my parkervision wr1500 router
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
May 14, 2010 | ParkerVision SignalMAX WR1500 / SignalMAX...
How do i secure my network
Need to configure in setting area:
1. username / password authentication for connection
2. MAC address filters also.
Apr 07, 2010 | ParkerVision SIGNALMAX WR1500...
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Mar 24, 2010 | ParkerVision SignalMAX WR1500 / SignalMAX...
New internet provider and now can not use remote viewing
If you have changed Internet Providers (which I assume you have considering you refer to changing from DSL to Cable modem), your "location" on the Internet has also changed.
Try going through the setup process with your Slingbox again as if it were the first time you had installed it.
Mar 18, 2009 | ParkerVision SignalMAX WR1500 / SignalMAX...
Voltage/Ma of AC adapter for WR1500??
The power supply on my ParkerVision WR1500 router is 12 vdc, 1.2a, center pin positive. http://straylightsoftware.com/downloads/parker2.html
Oct 29, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to 192.168.1.1, subnet mask to 255.255.255.0 and DHCP sever enabled with a pool of 8 IP addresses starting at 192.168.1.33.
note my unit resets to ip 192.168.150.1
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
MacBook Pro/ ParkerVision SIGNALMAX WR1500/ Compatability?
It looks like the product is no longer supported by ParkerVision and no Mac driver was ever produced. The device you mention uses proprietary technology to get the performance you are seeing.
http://www.wi-fiplanet.com/reviews/article.php/3445641
I would bet that it would be easier to replace your router with a new one that uses industry standards that all platforms support.
Mar 26, 2008 | Apple MacBook Pro Notebook
Reconnection problem
first try conecting a defrent computer ot the router then try to connect to the net. if that don`t work then update the firmware try here http://itchy.parkervision.com/support/WiFi/downloads/index.php if that don`t work then call 937-278-9141.
Aug 29, 2006 | ParkerVision SIGNALMAX WR1500...
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
62 people viewed this question
Top ParkerVision Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
