Question about Kenmore Dryers
My kenmore series 70 dryer belt broke,,, i find the idler laying on the bottom of the dryer,, i cannot figure out how to re attach teh idler to the machine and the belt going onit,,, got a picture to show me>?
    President:
  • 1,430 Answers
Try this link it should help Dryer belt replacement
Posted on Oct 16, 2010
Kenmore 70 Series Dryer Belt Keeps Breaking
A few things to check. Make sure that the idler pulley is turning freely without any signs of distress from the bearings. Make sure that when the belt is installed that all drum, motor and pulleys are perfectly in line. Even a small amount of misalignment will cause premature failure. Turn the drum by hand and make sure is turns fairly freely. There will be some drag from the drum supports, but it should turn readily with one hand, if it is any stiffer then the drum supports may be badly worn and will need to be replaced. Make sure that the pulleys on the motor and idler are in good condition and not damaging the belt. There are basically only three main reason for a premature failure, misalignment, pulley damage and overloading. It has to be pone of those.
Nov 26, 2017 | Kenmore Whirlpool Maytag Dryer Belt...
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
How do I replace the dryer belt on a kenmore 70 series dryer
remove two phillips screws under lint screen trap door pop lid up... remove two corner screws usualy 5/16 nut driver lift upward and off to the right idler pulley bottom left pat attention to belt routing before taken off relace pulley change belt and repeat steps and reinstall
Jan 31, 2011 | Kenmore Dryers
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
Motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
May 18, 2009 | Kenmore Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
181 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
