Question about GPS
My xsara speedo dosn't work but then it will conect. when it drops out the car also miss's.So its kinda an electrical problem
  • 712 Answers
Will you be more clear about your problem, please?
Posted on Oct 16, 2010
How do i change the time and date on citroen xsara piccasso o2 model ?
look at the dash board in front of you the left button where the speedo is push and hold clock will flash use the right hand stalk to rotate the time and date
Oct 18, 2014 | 2001 Citroen Xsara Picasso
Fitted new speed sensor to my 2002 xsara picasso but still showing speed too fast can you help ?
How fast is too fast? If it's within 10% that's probably as good as you will get without taking it to a specialist.
You can try to calibrate it by taking the speedo needle off and moving it very slightly forward of back but it's risky and hard to get right. I got mine to just under 10% doing it this way.
May 19, 2014 | 2004 Citroen Xsara Picasso
Removing dashboard
If there is an error code relating to VSS, then check at the transmission near the drive shaft side or final drive side. The sensor is pushed into the transmission.
Apr 19, 2014 | 2001 Citroen Xsara
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
I have a 1983 porsche 944 when I start it up in the morning it Idles at 1800 rpm and when I put it in drive it drops down to 1100 rpms and kinda runs rough any solutions to this
check engine light? If not add injector cleaner to a full tank of hightest. if that dosn't work do a complete tun up. also look for cracked or collapsed vacume hoses. keep in mind there are also vac hoses aroudd the gas tank area.
Mar 29, 2012 | 1983 Porsche 944
Speedo meter on the fiesta 2007 drops intermittently and comes back on. radio volume drops and car loses power slightly
Sounds like your alternator is trying to die out on you. Take it to the dealer to check the voltage that it's reading whenever the cars running, and when its not. Also, check the connector wires that connect to the alternator for bad spots. Or to see if the connectors are dirty. Hope this helps, James Booth
May 17, 2011 | Ford Focus Cars & Trucks
I have an 02 Volsuia 805. My speedometer quit working. When I bought the bike I noticed that the left side insulator for the fuel tank was missing. I replaced it. I think the issue with the speedo is the...
Have you had the front wheel off at any point?
What usually happens is the magnetic speed sensor is not lined up correctly when the wheel is replaced and breaks. This is a common occurrence.
Sep 14, 2010 | 2002 Suzuki VL 800 Volusia
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
