Question about Jandy Ae3000t 131,000 Btu Heat Pump
How hot or what temp is 131,000 btu's - Jandy Ae3000t 131,000 Btu Heat Pump
  • 990 Answers
1 results for: british thermal unit British thermal unit ' noun Main Entry: British thermal unit Function: noun Date: 1876 Results
1876the quantity of heat required to raise the temperature of one pound of water one degree Fahrenheit at a specified temperature (as 39°F) Merriam-Webster Online Dictionary copyright © 2010 by Merriam-Webster, incorporated This is what a BTU is and you have 131,000 of these being produced at any given time by your heater. So this is not a temp or a heat it's the potential to raise heat in a certain amount of time. That is to say if you want to heat water for tea a good fire is better than a match. Both are hot and will burn but a good fire has more btu's and will burn a lot more. If you have the gallons of water a pint weighs about a pound so it should take eight BTU's to warm a gallon of water one degree. 131,000 should warm 16,375 gallong one degree in a hour. This expecally with a heat pump is all reletave. Sunny calm day's do much better than cloudyand windy days and so forth. A gas heater will always produce on a steady rate. I know this is a lot of HooGoo but their you have it. It's not a heat but a measurement of potential.
Posted on Oct 17, 2010
What is a high limit condition
temp sensor failure. when sensor read temps that are way too cold or way too hot
Apr 21, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
When heater reaches controlled temp and shuts off it will not re light.
This sounds like a bad thermostat. Myself I run them wide open and unplug it if it gets to hot.You can replace it or follow my lead and just unplug it when it is hot enough.
Dec 26, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
My heat exchanger is cracked
You might be able to get it repaired ... best bet is to replace the exchanger.
May 22, 2010 | Jandy Ae3000t 131,000 Btu Heat Pump
Heating pool very slow outside temp is 70 30000 gal pool . Ran 10 hrs went from 81 to only 83 131000 btu unit !
With an outside temp of 70 your probally getting down to the 40's at night wich is to cool to get much heat rise and with 30,000 gal this will take a few days to raise the temp much also you should have a cover for a pool that big. If you have any wind the pool will loose 90 persent of it's heat from the surface. Once it is warm the heat pump will keep it warm for cheap if it is covered and you run it in the day.
Oct 18, 2009 | Jandy Ae3000t 131,000 Btu Heat Pump
NO HOT WATER ONLY COLD
First check to see if your temp. dial is not set on vacation or pilot and set it to hot or very hot which you prefer and it should fire rite-up if not, call a plumber 'cos you have a bigger problem...lazgo
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Jandy Ae3000t 131,000 Btu Heat Pump Logo
340 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
