Question about Honeywell Televison & Video
I need the tv remote control code for the HONEYWELL 42 INCH LCD TV
  • Laurie Limerick
    Laurie Limerick Mar 20, 2015
    I tried code 006. It worked for many of the features, but not all.
I have a honeywell 42 in tv cant find remote and keys are locked....been lookin on line but hitting a dead end any suggestions
Posted on Nov 25, 2013
  • 4 Answers
SOURCE: Remote control code for a Toshiba Regza 46'' LCD TV
0154 0156 0060 1256 0845 0832 1356 0650
Posted on Dec 21, 2008
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Posted on Dec 29, 2008
  • 273 Answers
SOURCE: technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Posted on Jun 03, 2009
SOURCE: remote control code for the MXT LCD TV
MXT 15.4 LCD 1561D 12V 60W No operation instructions can you help me please
Posted on Aug 08, 2009
SOURCE: Emerson Jumbo Universal Remote, Need code for 42" Polaroid TV
Olevia 237V HDTV will not tune in 50-1 using antenna any more
Posted on Dec 29, 2009
Element 32 in tv
Element 32 in tv - Fixya
www.fixya.com > Forum > Flat Panel Televisions > Element
38 mins ago - element 32 in tv Need a code to run the volume and on off shaw direct sat. - Element Flat Panel Televisions question.
Remote Control Code for Element LCD TV -- & Direct ... - Fixya
www.fixya.com/support/t1101060-remote_control_code_element_lcd_tv
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
Element 32" 1080p TV (ELDFW322): Unboxing & Setup ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Jan 20, 2016 | Element Televison & Video
I need help findind replacement a remote for my 40inch honeywell avanza model SE40B1
0028,0027,0021,0000 are the common codes can be used with Honeywell Brand. To select a suitable universal remote control to your TV, you should first find out which brand remote control have setup code/s to your brand TV. The set-up code may differ to that given above. . If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Try these links, and check out which brand remote control have set-up codes to your Honeywell brand TV; and buy that brand remote control, according to availability. The brand name to remote control you are going to buy isn't a matter, but there should have setup codes to your TV brand, in the code list of the remote control. The code list will be attached with each brand universal remote control. Setup code list to some popular remote controls are given here by the above sites, for your reference. Check the sites with patience.
Oct 30, 2013 | LG 42LG50 42 in. LCD HDTV
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Sep 09, 2011 | Sanyo 42 in. LCD TV
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
Remote code Directv
try vizio under tv tv brand in the direct tv remote control codes.
Aug 02, 2009 | Honeywell CE2Y-PPT Remote Control
My grandmother has a 42 inch sylvania lcd tv need remote code for
Usually universal remotes have a auto select option, Check for the remote code online, go to gogle and search for universal remote codes
Jul 12, 2009 | Televison & Video
Need code
Try this
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0117
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Feb 18, 2009 | Emerson Televison & Video
Jul 25, 2008 | Zenith ZEN700 Remote Control
Remote control
x37sv-naga.lcd remote control
Dec 16, 2007 | Televison & Video
Televison & Video Logo
1,262 people viewed this question
Top Honeywell Televison & Video Experts
mikemail1
Ron Durham
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
