Question about Ingersoll Air Tools & Compressors
My ingorsall starts too flucsuate after about a minute of running it fills the tank to about 50 psi then the breaker trips on the motor (1/R#6283138) i havent run it in 3yrs i think its over heating is there a solution besides buying a new motor? It worked fine before. Thanks
    Brigadier General:
  • 4,088 Answers
The problem may be in the compressor--lack of oil, rusted cylinders and rings, water in the oil. Try uncoupling the motor from the compressor and run the motor free of load--check it's temperature after it has run for a while, then run it for about an equal time more. If the temps are barely warm, the motor is probably ok. If it gets hot, then check the capacitor(s) on the motor for condition, and turn the shaft by hand to check the condition of the bearings. If the motor is 3-phase, one of the phases may be missing. If the bearings have grease 'zerks', try greasing them. These problems are a relatively easy fix. Hope this helps!
Posted on Oct 16, 2010
Compressors kicks breaker at 60 psi.
This is usually caused by long extension cord, leaking check valve or weak capacitor. Most likely leaking check valve. Easy to check, run compressor for a couple of minutes and shut off. Listen for air leaking from pressure switch or at the intake filter. If leaking, let out air and remove check valve and look for debris stuck under the valve seat. To find the checkvalve, follow the air discharge tube from the head of the compressor to the tank. You should find a brass or chrome valve threaded into the tank. If check valve is not leaking, suspect weak capacitor or long cord (motor shop will test cap for free). Good luck
Apr 02, 2013 | Craftsman Air Tools & Compressors
I have a sears air compressor model 919.167310. I just replaced the run capacitor as it would not run and it was tripping the breaker. When I plug it in with not air in the tank, it will run fine, fill to...
If you have had the capacitor checked and all running fine, then the next thing to check would be the check valve, there should be a pipe that goes from your pressure switch to the tank, at the tank-end of this pipe, there should be the check valve. When there is no pressure in the tank! unscrew the check valve remove the spring and valve and check it is clean and servicable. Put it back together then try your compressor again.
If there is no improvement, are you running your compressor with an extension lead? try plugging it into the wall directly, you can lose vital power through a long lead. Also, ensure you don;t have too many machines running whilst you are using your compressor, this could be the problem, as they may be using most of the power
Finally, if you have checked all the above, then you may want to get your motor checked out, to me it sounds like a power issue from what you tell me.
Try the above, and let me know how you get on
Thanks Carl
Sep 22, 2012 | Air Tools & Compressors
I got one of your compressors off a friend that had not used the unit in years, it say in his garage and collected dust. So I changed the plug and wires, got a new outlet in my garage for a 230 line and...
With pressure in tank test for leak at the check valve. Follow the discharge line from the pump to the tank. There you will find the checkvalve (usually brass valve). If the check valve leaks the compressor will be under load when motor tries to start and will probably trip breaker. Look for reset button (red button )on the compressor motor and push-in to reset. With pressure in tank the motor /pump should turn freely by hand. If checkvalve good and unit turns freely, test capacitor for proper valve. It should test to within 95% of printed uf/mfd. Good holidays
Dec 15, 2010 | Puma Air Tools & Compressors
My compressor sat idle for just over a year. Before it was idled, I bled it down completely and closed the drain valve. When I re-started it this year, the motor was very sluggish as if there were a heavy...
Down time is ******* motor capacitors , replace motor capacitors , start or run capacitors , usually on outside of motor . Under a cover with one or two screws . They will be marked with voltage and microfereds ratings .....
Jun 11, 2017 | Porter Cable C6110 150 PSI 25 Gal OilFree...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Air compressor trips motor breaker
PLEASE CHECK THE CAPACTORS ON THE MTR, THE MTR WILL BE HARDER TO START AFTER IT HAS AIR IN THE TANK
Nov 26, 2008 | Air Tools & Compressors
Craftsman 6hp / 60gal air compressor
Does this trip on pressure or is it a breaker tripping? If you took off the intake then there is no pressure build up, thus it wouldn't trip the pressure switch. But would at the same time add a load to the motor. First check and make sure motor is wired properly, then check that pressure switch is wired properly and is adjusted to the right pressure. I don't believe that the intake tube would be clogged, it's a straight hole into the tank. But could be a possibility.
Oct 23, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
52 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
