Question about Toshiba Satellite A70-S249 Notebook
The CMOS battery Toshiba A70 notebook. If damaged the notebook crashes?? The DVD or the wireless card can lock the notebook to the point of not caring nothing?? My note A70 stopped this whole ... and when I turn on the LED flashes only source of strength and erases ... Only used with source ... the battery died long ago ... and now I can order a casket for my a70, or it will still give the leather?? I repeat: I suspect the CMOS battery - DVD drive - wireless card; What can be? A hug. djnabuco@hotmail.com djnabuco@ig.com.br ----------------------------------------------------------------------- in portuguese: A bateria CMOS do notebook toshiba A70. Se estiver danificada trava o notebook ??? O DVD ou a placa wireless pode travar o notebook a ponto de não ligar nada ??? Meu note A70 esta parado total... e quando ligo a fonte só pisca o led de força e apaga... Só usava com fonte ... a bateria morreu faz tempo... e agora posso encomendar o caixão pro meu a70, ou ele ainda vai dar no couro ??? Repito: desconfio da pilha cmos - drive dvd - placa wireless; O que pode ser ? Um abraço. djnabuco@hotmail.com djnabuco@ig.com.br
    Master:
    Sergeant:
  • 381 Answers
Better of investing in a new laptop this has too many problems
Posted on Oct 16, 2010
What if you are missing a CMOS battery on a toshiba A70?
The battery keeps voltage on your bios to keep the date, time and settings... without it the computer will boot up but not as smooth as one with the battery replaced
Oct 15, 2013 | TOSHIBA Satellite A70-S2561 Main battery...
10 beeps ( 3 short pause 4 short pause 3 short) Toshiba satellite a70
The beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM modules and Cmos battery has charge and dust free sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) SATA make sure they have a secure connection
check your video card for secure dust free socket
and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error
a computer needs power and data to travel through every working device and have an end to function properly
even something as small as a faulty fan lead can cause this problem computer needs all of the data and power to travel through every device and to have an end to be able work properly
hope this helps
Jul 12, 2012 | TOSHIBA Satellite A70-S2561 Main battery...
What wireless router do I need for my Toshiba A70/A75 series laptop?
I checked the specification of this notebook PC and it uses a 802.11 b/g wireless adapter. You can purchase any brand of wireless router just make sure that it supports 802.11 b/g.
You can get a D-Link WBR-2310 108Mbps 802.11g Wireless 4-Port Router at ebay for around $20.00
Hope this help. Goodluck!
Mar 27, 2011 | Toshiba Satellite A70: A70 Intel Pentium 4...
Where is the cmos battery located in the computer??????????
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Oct 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
System date keeps going back by one year everytime i restart the machine
It's time to change the CMOS battery in the Motherboard.
It will solve your problem.
On how to find the CMOS battery
you will have to open up the '**** shell' and remove all of the B25 and F6 screws from the bottom, as well as the B16 and B6 screws under the keyboard. To remove the keyboard, you have to pry up the trim piece that holds the power button and remove three screws. Be careful of the wireless wire leads, as you'll be tempted rip them out!
The CMOS battery will be under the right side of the hand rest, next to the mouse. It has two leads and the battery is in a blue 'bag'.
That's it.
Jan 07, 2010 | Toshiba Satellite A70-S249 Notebook
I WANT TO RESET MY TOSHIBA A70 TO OUT OF THE BOX SETINGS I DONT CARE IF EVERYTHING IS ERASED
1. Restart your system.
2. When the POST screen comes, press F8 key repeatedly untill you see the 'Advanced Boot Options' screen.
3. Select "Repair Your Computer ".
4. A windows will open, select "Comlpete PC Restore" Or "Full Factory Recovery" option.
5. Follow the instructions.
6. It will ask you to "Select the Recovery Location / Drive" Or "Insert the Recovery CD/DVD"!
7. Now, the recovery process will start. It will take about 30-45 minutes.
8. You will get the options like : "Partition all drives", "Format all drives", "Fromat System drive (C: drive)", etc.
9. Select only "Format system drive (C: drive)". This helps you to prevent erasing your data on other drives (like, D: ,E: ,F: , etc) .
10. The system will restart multiple times and you will get message "Recovery Successful"!
11. Don't forget to create a 'Restore Point' after successful recovery...it will help later in case of any crash!
tell me if it helps...tc! :)
Jan 04, 2010 | Toshiba Satellite A70 Notebook
Cannot turn on the wieless network device for toshiba A70
There is a switch on the side of your laptop with enables and disables the wireless card in your laptop. Make sure it is on and lit.
Mar 04, 2009 | Toshiba A70-S256 Notebook
A70 hard drive crashed ,cdrom is not readable to recover
From your description of the issue, the most likely senario is a hard drive failure. Replacement hard drives run $50 to 100 or so and are generally fairly easy to change
Jan 25, 2009 | Toshiba Satellite A70 Notebook
Toshiba Tecra M2vS330- crashes when wireless card switched to "on
Hi, your problem does not have to see with the openoffice that download, It coincides with your card mini - pci wireless I damage, and is for it that whenever you ignite the wireless your Laptop restarts for hardware malfunction. the solution is to replace the mini wireless board.
Jan 09, 2009 | Toshiba Tecra M2V-S330 Notebook
Toshiba Cd drive won't close
There must be a small part locking mechanism that broke or lose thread inside your dvd drive. gently open it and you will see it.
Apr 20, 2008 | Toshiba Satellite A70 Notebook
Toshiba Satellite A70-S249 Notebook Logo
228 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
