Question about Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS
I have the WH21 Timer and the lightis bright when it is heating, and only goes to dim when it shuts off.Should the light go out completely when it goes off?Water gets extemely hot,so I cut it back one notch to 4.What usally goes out ,the thermastat or timer?Have been getting what seems like a lot of air when you turn on the faucets in any room.Thanks Don
  • dadoman02 Oct 17, 2010
    Hi Fredy,There was a loud pop and the bulb went out on the Intermatic Timer.Have been getting a lot of spitting pressure from all faucets.I turned the temp down yesterday, but last night it pop the light out on timer.Have drained the tank and not too much lime came out.Trying to check the lower element.Still had spitting pressure after turning temp down,giving it time to cool down.Don
  • dadoman02 Oct 18, 2010
    Hi Fredy,I already fixed the problem .It was the Heating elements,so i bought the thermostat and element kit and spent most of the day draining the tank and replaceing the parts .Bottom element was toasted and blown out.This was causing the singing effect when it started heating.Used a wet vac and cleaned out bottom of tank.Lots of lime deposits on top element also.Runs quitely now and heats great.did not need advise after all.
  • 5,603 Answers
Overtemperature is a failed thermostat. Most heaterss have two of them and they are adjustable. Set them back to around 140.
Often devices that have an indicator lamp the is the incandescent type do NOT let the bulb go out completely, but maintain a low dim light level. This reduces the starting surge that usually pops the filament in the bulb as it ages. By keeping the lamp on dim, the surge is mostly eliminated and lamp life is greatly extended.
Posted on Oct 17, 2010
  • Fred Yearian Oct 18, 2010
    It sounds like a major failure in the tank. If the tank is beyond the warranty time it likely has thermostats and or element problems. At that point best to replace the tank. Most the elements run from 220 and as a result if they cut through to the case they are a direct short from one side of the line to ground. If the tank is relatively new and under warranty exercise the warranty as long as they don't rip you off for labor... Other than that using an ohmmeter should diagnose the actual cause.
    You see if the element shorts on the side opposite the thermostat, then that will continue to heat in spite of the thermostat opening. These Calrod heaters often develop shorts near the bends of the element rods. If you find a shorted element, that is probably worth replacing as they are usually under $20. Use Rectorseal and you need a special wrench to unscrew them that costs about $12 at Home Depot.
    While you had the tank open I would have suggested you replace the sacrificial anode... that extends the life of the tank. They either get eaten away or covered with lime and become ineffective. There are how to's on YouTube about this.
Changed the batteries in timer/thermostat but the boiler is still not talking to the transmitter heating still on can you help??
Is this a wireless system, meaning no wires between the thermostat and the boiler? If so, check to see if the code buttons have been reset. If this is a hardwire system, the relay on your control board may be stuck. In any case, you can always shut off the boiler by turning off the gas and/or circuit breakers.
May 31, 2016 | Water Heaters
Hot water heater keeps shutting off.
This sounds like a circuit board has a component that may be heating up and failing. When the unit is unplugged power is shut off to the circuit board, which will allow the component to cool down and start to work again. If this is the case then the component will fail completely at some time.
Dec 22, 2015 | Water Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
WATER HEATER GOES OUT OVER NIGHT
you either have a back draft blowing out the pilot light, or a bad thermal coupling. if coupling is bad it will shut down the gas flow therefore shutting off pilot light. its a safety measure to stop the gas flow if pilot goes out. replace thermal coupling, that may do it. good-day ! but shut off gas first !
Mar 21, 2012 | Water Heaters
I have a gas heater that keeps shutting offf. The power is turned on but within hours it cuts off. mariaram@aol.com
the thermal coupling may be bad!! if the coupling goes bad it will shut down flame. its a safety feature, if gas comes out, and no flame it shuts gas off. the coupling is in pilot light flame and works on the same principle as a thermometer to sense the heat. good luck !!
Nov 18, 2010 | Rheem Tankless Hot Water Heater...
AO Smith Burner Issues
This system uses an electrical test to make sure that the burner is lit. The flame sensor will either be broken or will be covered in deposits (clean with an emery cloth).
The flame sensor is usually a small metal rod that would be in the direct line of fire of the burner with 1 wire attached.
CAUTION:
The ignitors can be very fragile and are expensive. They are very brittle, do not touch it.
Jun 07, 2010 | Water Heaters
After heating pilot goes out . my igniter is bad so i light manually and after heating main burner shuts off and so does pilot
The thermocouple that controls the gas to the pilot light must be bad. The thermocouple, when it is heated by the pilot light keeps a valve open that keeps gas flowing to the the pilot light. This thermocouple closes the valve that supplies gas to the pilot light, this is to prevent gas from continuing to escape when the pilot light goes out. This is a safety issue, I recommend that you call a professional about this problem. You might be able to repair it your self by replacing the thermocouple but I still recommend that you have it checked by a professional.
Dec 02, 2009 | Whirlpool Water Heaters
The pilot light blows out every time the main burner shuts off. It will light, the main burner comes on, everything seems ok until the main burner shuts off, then the pilot light goes off also as if the...
it's the thermocoupler ( about $20 ) that is bad replace it. if that doesnt do it it is the box with the on/off/ pilot button ( about $175 ) I found a complete unit at www.americanrvcompany.com for $275 plus shipping ($300 total) and that is how i fixed the exact problem with mine.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
How do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Feb 11, 2009 | Element Chromalox SG1353-430326 Electric...
Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS Logo
Top Intermatic Water Heaters Experts
Gary Nitowski
Gene Haynes
Tom Chichester
Are you an Intermatic Water Heater Expert? Answer questions, earn points and help others
