Question about Braun Flex Integral 5416 Electric Shaver
How to open 5416 to replace battery- this unit is older and has no recharging base
  • Braun Master
  • 1,610 Answers
You will find a compatible battery at shaveroutlet.com
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To disassemble the shaver, start by removing the foil and cutter. Then remove the two tiny screws that hold on the swivel frame. Next, remove the two round screw covers on the bottom by prying them out. Remove screws found underneath. You can then gently pry the front and back covers apart from the bottom
Posted on Oct 17, 2010
Battery charging and control, electric start. Need schematic and parts list.
The UT number for this generator is UT-03559. The problem is like yours can't find anything online in the line parts or owners manuals for this unit. You may try http://www.ktoutdoor.com/
They were listing this number. doesn't mean they have anything on it but might be worth a try.
Here is alternate idea on recharging the battery use a 12 dc ac adapter for recharging while the unit is in use.
Feb 26, 2015 | Electrical Supplies
Wsi-op200 won't hold charge
The short answer is: buy a new one. The long answer is: the battery can be replaced with a ATC Cordless Phone Battery 3.6V NiMH for Sanik 3SNAAA55HSJ1 3SNAAA60HSJ1 series (amazon, $3.16)(this battery is the correct size and volt, but has a higher milliamp rating) This, actually, is a battery for a cordless phone. The old battery is not meant to be replaced, but this one will work. To do this: 1) remove the base from the unit, 4 screws can be removed with a long narrow Philips head screw driver. you can insinuate the driver into the corkscrew area. 2) pry off the black switch, this can be done with a small flat screwdriver. 3) slide off the silver sleeve from the unit. 4) separate the black plastic clamshell pieces by removing four screws. 5) remove tape form battery and cut wires next to battery. 6) use a dremmel grinder to create more space at inner side of plastic base part(battery will not allow unit to close as it is flat and OEM battery is curved) 7) solder battery leads to unit leads(electrical tape to cover solders). 8) screw unit together. 9) put axle for switch back into place and slide silver sleeve back over unit.(may need some lubricant and coaxing) 10) screw base back to unit(may need to carefully tape screws to driver so you can get them into place 11) recharge(1-2 hours of work).......or BUY A NEW UNIT.
Dec 27, 2013 | Sharper Image Electric Wine Opener -...
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
Base not charging parent monitor
The rechargeable battery will need to be replaced.
Mar 20, 2012 | Angelcare Ac401 Deluxe Baby Movement Sound...
The base unit for my Philips VOIP3212S is not charging the phone I need to buy a replacement base unit. I put ordinary batteries in the phone and the base unit no longer works
Wilson - The phone was not made to use regular (AAA) batteries. Unless you install AAA NIMH rechargeables it will not work. Regular AAA batteries cannot be charged by the base unit.
In case you meant AAA NIMH batteries as "ordinary batteries" then your charger may be the problem, but I wouldn't assume that until I've taken a pencil eraser and vigorously cleaned the base contacts and tried the base again (with the right batteries.)
Good Luck, Mikeywaf
Mar 07, 2011 | Philips VOIP3212S/05 IP Wireless Phone
I get a blinking yellow light when recharging my IRobot Roomba 550. What's wrong?
I am afraid you are having the problem of old or weak batteries. Old batteries at times tend to show such problems and do not show charge while charging properly. For this purpose, you can use a reliable Nicad Battery Repair Guide through which you can recharge the batteries without any problem and make them work like the new ones within no time, without anyone's help and you can do this all by sitting at home! I tried it and now I never buy new nicad batteries (http://www.nicadbatteryrepair.com/).
Jan 03, 2011 | iRobot Roomba 550 Vacuum
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
One of the handsets does not work. the other two handsets are OK
Probably defective unit.Try and get it replaced.
On another note, when these phones act like they are going to **** out on you in about a year (manufacturers often use the lowest bidder for batteries on these), replace the batteries with Energizer rechargeable equivalent. That exact scenario worked great for me and my older Panasonic setup is running 4 years strong on the Energizers.
Mar 03, 2009 | Panasonic KX-TG1033S Cordless Phone
Battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Dec 28, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Braun Flex Integral 5416 Electric Shaver Logo
225 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
