Question about Radio Communications
Installation I just installed a Motorola M1225 mobile radio and it does not power up. I tried another radio that I had and no luck. I have power to the unit. Isn't it as easy as power, ground and an antenna? Please Help.
    Sergeant:
  • 250 Answers
Hello chiefcso54,
Most mobile radios need only a power connection and an antenna. If neither of the two radios you tried are actually powering up, you will want to check to make sure you actually have power at the power connector.
You should see approx 12 VDC using a voltmeter at the power connector. If you don't then check your installation, make sure you don't have any blown fuses, etc.
Ideally you want the power lines for the radio to connect directly to the automobile battery. If you are getting power from somewhere else in the car's electrical system then you may actually need to have the car running (or the key turned to the ON position) for the radio to get power.
If you have power at the connector and the radio still won't turn on then you might have a problem with the radio itself.
Hope that helps,
Ken
"Go Ahead. Use us."
Posted on Jun 04, 2008
How do I down load users manual
I am surprised by how hard this is to find. My old links are gone, Motorola Solutions did not bother to carry the links over. So, the manual is very similar to the P1225 and the M1225 (mobile), the LS adds the Trunking features. Nothing is user programmable. The buttons on the front must be programmed by the dealer to do anything, but were usually a direct channel and resume (back to trunked operation). To make any changes, you need the Motorola software, cable and RIB (radio interface box). Parts are still available. They were rugged, good radios we sold hundreds of.
Oct 08, 2015 | Motorola Radio Communications
How to service
Will you please explain what the problem you faces with your radio? If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 09, 2014 | Motorola Radius M1225 Two Way Uhf Radio...
THE DISPLAY IS SCRAMBLED AND THE RADIO WILL NOT READ OR WRITE ON A MOTOROLA M1225 RADIO
You have a corrupted codeplug, most likely. The radio will needed to be serviced by Motorola or a service facility with the ability to wipe the radio and reinstall the firmware and codeplug.
Sep 17, 2009 | Motorola Radio Communications
How to program
The M1225 mobile is Motorola dealer programmable using the appropriate Motorola software, radio interface box (RIB) and programming cable. The cost for this type of programming is generally $15-$25.
May 30, 2009 | Motorola Radio Communications
V3i application
is it possible to download fm radio software in motorazr v3i
Apr 09, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola m1225 two-way radio
First, check the antenna connection,the SWR of your antenna and you can also use the SWR meter for outpu power checking,the frequency it migth be on a duplex mode,you can check the frwuency by using a frequency counter....
Mar 01, 2008 | Radio Communications
Keys does not function
my guess is that the battery is too weak install new ones and see if it works out good luck windman
Oct 25, 2005 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
