Question about Sun Mountain Speed Cart V1
How do I remove the front wheel on my Speed Cart V1 so I can relace teh inner tube? Is there a user manual with instructions/diagrams?
2 Suggested Answers
SOURCE: Sun Mountain Speed Cart V1 users guide
I am trying to replace the lower bag holder with the new non bungie type. They didn't send instructions. Do I have to drill new holes in the frame to make this assembly work? The top one was a straight replacement.
Posted on Mar 27, 2011
What is the right air pressure for sun mountain golf cart
8.What is the recommended tire pressure for the Speed Cart pneumatic tires?
The recommended tire pressure is 30 psi.
FAQ ' Customer Care - Sun Mountain
https://shop.sunmountain.com/faq.html
You may also purchase products directly from any of the preferred internet retailers or shop.sunmountain.com. ... If the tire pressure checks out and you have a cart outfitted with bungee cords or strapless bag bag bracket you can adjust the alignment by following the instructions in your user's guide. If you have an older cart ...
[PDF]Speed Cart® SVl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/SV1_UserGuide.pdf are perfect for balls, tees, snacks and keys. • Mesh headcover tray. accessories include the. Speed Paq and. Umbrella. • Ergonomically designed to push without straining your shoulders or back. • Large diameter f tires are maintenance free. I. • The E-Z Latch System / makes folding and unfolding the cart simple.
[PDF]Speed Cart® V2 User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V2SpeedCartUserGuide.pdf Speed Cart® V2. User's Guide. To take full advantage of the ergonomic features of your new Sun Mountain. Speed Cart, please read the following information. ... on the side of the brackets, place your golf bag on the cart and retighten the thumb ... your manual brake is not holding, first check the tire pressure on the front.
[PDF]Speed Cart Vl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V1SpeedCartUserGuide.pdf *Reverse these steps to fold and store your Speed Cart. STEP FOUR: STEERING. To steer your Speed Cart push down on the handle so the front wheel lifts slightly off the ground. Then pivot tight or left to change direction, lower the front wheel and go. When adjusting the handle or folding the cart, please note that the tires.
sun mountain golf cart tire pressure Google Search
Mar 12, 2018 | Golf
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
Callaway crosstrax push cart front flat repair
I too searched the internet. I have Calloway Crosstrax push cart. I put too much air in front tires and it blew. Be sure to put only 28psi of pressure in that front tire. These tubes cost at least $10. I Finally figured it out how to take this darn wheel off to replace tube. After 2 hours and revisiting after having a beer it came to me. Remove the two screws on each side of the wheel. Unloosen hex screw at bottom of fork. You don't have to remove the hex screw and not sure if it has to be unloosened. The key is to get pair of grip plyers and pull those black end caps out. A little on each side at a time. The tire assembly comes right out. Don't forget to release brake from closed position. Hope this helps.
May 06, 2014 | Optics
Adjust break
Follow the brake cable from down the cart until you find the tension bolt. To tighten turn to the left. If you are not comfortable working on the cart, most bicycle shops can repair them for a small fee.
Sep 04, 2013 | Sun Mountain Sports Golf Speed Cart V1
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
Apr 05, 2010 | Sun Mountain Speed Cart V1
Where can I find a brake cable for my Sun Mountain speed Cart v1?
Call sun mountain and they will send a new cable for free.
Sep 08, 2009 | Sun Mountain Speed Cart V1
Front wheel of stroller has a hole in it.
Go to your nearest bicycle shop and buy a puncture repair kit. It's real easy to use or you can ask the staff in teh shop to do it for you.
Jul 07, 2009 | Schwinn Runner ST Jogging Jogger Stroller
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Sun Mountain Speed Cart V1  Logo
133 people viewed this question
Top Sun Cycling Experts
Tom Chichester
Bill Boyd
Donald Ayers-Marsh
Are you a Sun Cycling Expert? Answer questions, earn points and help others
