Question about Kenmore Dishwashers
There is standing water in the drain hose of my dishwasher.
    President:
  • 1,891 Answers
In most dishwashers it is normal for the water to remain in the hose . if it install properly the hose will be hooked to the side of the disposal and at that point the hose should have a upward lift to the underneath of the counter and then down to the dishwasher / this creates a reverse trap and prevents food from the disposal getting back to the dishwasher . ( it also prevents the d/w from smells and flooding . the water that is still in the hose should only be rinse water from the final pump out of the d/w cycle . about a cup to two would be normal . i hope this answered your question . please give feed back and if i can help with another questions mm thanks for using fix-ya mm .
Posted on Oct 16, 2010
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
For the person whose plumber disconnected the dishwasher, let me guess - he replaced your garbage disposal.
Most garbage disposals have a plug that seals the dishwasher inlet by default. This plug will need to be removed. You will have to refer to your garbage disposal's documentation to determine how to do this properly.
Posted on Jun 15, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
Standing water in dishwasher
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 30, 2012 | Frigidaire Dishwashers
Water standing in plugged drain. Did rinse but water is still standing.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Water standing in tub,already removed cleaned screens,also drain hose is not plugged,can feel spindle spinning on pump out motor.Would impeller be shot??....thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Kenmore 17252 Free-standing Dishwasher
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Our GE Dishwasher model GLD4500N00BB will only drain a small amount of water out of the dishwasher. there is water left standing after a wash. what is going on?
Look for restricted drain system. Screens and ports get plugged, also verify the drain hose is NOT kinked at all. Hot water draining relaxes hose and can cause restriction.
Oct 31, 2009 | Dishwashers
Water left standing inside the buttom of dishwasher
It depends on What kind of Dishwasher you have. If the pump is old it may very well be bad or it could be a drain hose routing issue. The drain hoseshould always be looped up in the cabinet under the sink. If the drain hose is laid down low, the water could be backing up from the hose back into the dishwasher.
Feb 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing water in my kenmore dishwasher after complete cycle
heatman101
z
Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
Jan 26, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
88 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
