Question about Nokia 6233 Cellular Phone
Changing front housing cover of Samsung U600
Trying to replace the front housing myself. I was sent a prying tool. Not sure what to do. Have you had any luck? i would like to know how to dimantle a nokia 6233 so i can remove a piece of broken power adapter
    Brigadier General:
  • 7,752 Answers
You should take the phone toa professional mobile center and have them replace it for you.
Posted on Aug 24, 2008
Replacing cracked screen
Insert your plastic pry tool into the seam in the side of your touch and run it along the length of the device to release the back panel from the front.
If your replacement screen did not come with a plastic pry tool, then a small flat-head screwdriver will also work.
Remove the square battery from the motherboard in the front housing by running the pry tool along the sides of it and gently pulling up.
Remove the small piece of black tape from the bottom of the front housing to expose three screws.
Remove the three screws using your small Phillips-head screwdriver. Remove the small screw near the top of the battery connector ribbon as well.
Remove the metal cover from the bottom of the front housing with the plastic pry tool.
This will expose the ribbon that connects the screen to the front housing and motherboard.
Flip the screen-connector ribbon up and gently pop it out. Then remove the two screws at the top of the front housing and disconnect the one other screen-connector ribbon.
This will release a thin metal board at the top of the housing that guards the screen. Pull the metal board out carefully.
Remove the 16 small screws from the side of the screen.
Once the screws are removed, the LCD screen will be free of the housing.
Gently remove the screen and replace it with the new one.
Replace the screws and reassemble the iPod touch the same way you took it apart.
video http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&view=detail&mid=3843F00F64220E3352823843F00F64220E335282&first=0&qpvt=how+to+replace+an+ipod+4g+screen
Nov 05, 2013 | Apple iPod touch
My samsung Galaxy s3 has its screen cracked. Is it worth putting a replacement screen on myself?
Hi Cement,
Sorry to hear about your Galaxy S3! Depending on the damage (if you can see the the video underneath and the touch feature works), some repair shops can fix your device for much less than the cost of a new phone. There is a company called Phone Doctors (www.PhoneDoctors.com) that offers a lens-only replacement for $150 via their mail-in repair service. These guys are AWESOME and fixed my friend's phone in no time at all. If for some reason your video is not displaying or your touch is not working, the worst-case scenario would be about $240 for a new screen (which is the LCD and Digitizer + Lens as a combined part).
I do not recommend trying the "glass only" fix as you run the risk of really messing stuff up unless you have the correct equipment, which Phone Doctors has. However, this repair can most likely extend the life of your device! :)
Oct 31, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
IPod touch-shattered screen, thou can still be used.can u replace the front screen?
yes it is but you will need some certain tools
video
hope this helps
http://www.ebay.com.au/itm/New-Touch-Screen-Digitizer-Glass-Replacement-iPod-Touch-4th-4-4G-Gen-White-/330783433649?pt=LH_DefaultDomain_0&hash=item4d043aa3b1
Au $11.54 + postage Au $2.95 worldwide
im not sure if this is the right one you need
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Oct 10, 2012 | Audio Players & Recorders
Where to buy charging pin cover for samsung U600 as replacement
hello
charging pin cover for samsung can be got at any outlet designated by samsung.though this depends on the country you are
Nov 18, 2010 | Samsung SGH-U600 Cellular Phone
Instruction to replace u600 slide flex cable
download the service manual for the sgh-u600.you need experience and special tools.isnt so easy.be carefull with the parts screws etc and check the rev. before order the flex cable.USE ONLY ORIGINAL!
Jul 16, 2009 | Samsung SGH-U600
HOW TO CHANGE REAR BRAKE LIGHTS 1999 QUEST?
I don't know this van but many tail light assembly's have a couple of screws you remove then a couple of snap clips. So after you remove the screws you gently pry the assembly off with a slim pry tool.
Feb 24, 2009 | 1999 Nissan Quest
Samsung sgh-u600 - display problem
Mine is also like this, but I now live in Spain. Will I still be able to take it back to the store when I am next in UK ( still within 12 months of buying it) or will they say they wont replace it, cos I have a Spanish SIM card in it now?
Thanks in advance
Ang
Aug 16, 2008 | Samsung SGH-U600
Nokia 6233 Cellular Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
