Question about Vacuums
I have an older Wega 2 group espresso machine. Looks like a date of 1992 on the group head, but not sure. This has no model name that I can find. Anyway, when I turn it on I get all lights flashing after it heats up 5 minutes or so. I do get nice steam from the wands. I drained teh tank and found a little scale, but not much. I took apart the group heads and cleaned them thinking it may be a clog there, but that doesn't seem to have worked. Also fwiw the water level float is not visible and when I try to add water with the lever it lets off a little drip/steam, but doesn't effect the float/water level as far as I can see.
  • 1 more comment
  • lwells2000 Oct 16, 2010
    what are you talking about? Stay away from my questions. I am asking about an espresso machine and you start talking non sensical bs about a fridge.
    The other answer was clueless idiot talking about a refrigerator. Anyone know about espresso machines?
    Much better thank you, sorry for the response!
  • 1,711 Answers
For a new fridge, need more time to maintain the required temperature of the fridge abut mainly the goods in it? So everything seems normal. The time will be reduced day by day since the goods will stay for longer time in and door opening will become less and less.
So don't worry everything seems fine.
Posted on Oct 16, 2010
  • espressonist
    espressonist Oct 16, 2010
    Sorry about that , here is your solution
    The all light flashing mean that the boiler refill take more time than it should be and in this case the machine stop the refill process that is why you don't see the water level float since the boiler it does not fill properly.
    So first of all you should check if the water pump work and you have the 9 bar pressure.
    If yes then the piping water inlet must be disassemble and clean from scale in order refill boiler freely. This is what we have got from your description.
    You can check the above and if you notice anything else you can comment it back and we can advice you accordingly.
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
Where can I get a tubing diagram for a Bissell Proheat 2x model 1383 deep clean carpet cleaner need ASAP please??
sadly we can not assist those who do not assist us or their selves . UNIDENTIFIED does nothing on a search
Feb 09, 2016 | Vacuums
I need an on/off switch for Fantom FM741B upright
Cathy, If I could see your machine I'd be more likely to be able to tell you whether or not you could get a switch or not. IF your machine is one of the older models then it's a good bet that there are no more switches available for them. I've heard that someone bought out the Fantom name and is now making them again. I think someone mentioned seeing an infomercial about them recently, but I can't be absolutely sure. If you take it to a reputable repair shop their mechanic may be able to find something that could work, but no promises.
Nov 10, 2013 | Vacuums
What year is my singer sewing machine? AH251729? how do I purchase parts for it, like the zig zag attachment?
The Singer vintage machine site indicates that the AH251729 was made in 1947 in Elizabeth, NJ. For details see http://www.singermachines.co.uk/faq/tell-sewing-machine-age-from-two-letter-serial-number/ .
Look on the front of your sewing machine and locate the model number of the machine. Go to http://www.singerco.com/support/replacement-parts-chart and locate your model number. (Use the drop down menu and locate the group. Press Go and then find the pdf with the correct model parts list.) You can look up the exact part number and order them from the Singer Service Center online.
Alternatively, you may be able to find them at any Singer Authorized retailer. Just look at your machine and determine the type of shank that connects foot to the machine. (High Shank and Slant are common Singer foot designs on older machines.) Get a zigzag foot for Singer machines with that design. (If they don't have that, you can probably get a current foot and an adapter. We got an overedge foot and the high slant foot adapter for my Singer sewing machine (purchased in 1969) in the 1980s.)
I hope this helps.
(Singer parts are generally available. I saw throat plates for some Featherweight machines this morning at a quilt show.)
Sep 04, 2011 | Singer Vacuums
As previously advised the steamer is letting water to escape which reduces the flow to the group head. Frank
which brand and model is your espresso machine if we undersatnd corect
Jul 10, 2011 | Vacuums
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
Manual for Janome Sewing Machine model 106
Try looking on the Janome site.
They don't have one for the 106 but they do have manuals available for similar machines.
http://www.janome.com/index.cfm/Machines
To find a manual, click on the underlined machine name or model number for the machine that looks most like your 106 and then click on specifications. Then just click on Download Manual.
Most machines by the same brand have similar parts and thread in the same way.
Hope this helps!
Sep 25, 2010 | Vacuums
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How to clean the power brush on the miele vacuum. Is the brush removable? If so how do you remove it?
Greetings from GoVacuum.com,
Miele canisters have 2 different types of power brushes. The first, and most popular is the Miele SEB 217, and 213 Power heads. To remove the brush, follow these instructions.
On the bottom of the power head there are 2 yellow (older models it is black) plastic screws. You can remove these screws with a phillips head, or flat head screw driver. Simply unscrew these two screws. You do NOT have to remove these screws, just unscrew them to where they are loose enough to remove the bottom plate.
Once you have unscrewed the plastic screws, simply pull the bottom plate up and off of the power brush. You will notice the belt on the left hand side of the brush. Simply pull the brush up, and un hook the belt from the brush;
Now that you have unhooked the brush from the belt, you may thoroughly clean the brush, and un wrap any hair or thread that is wrapped around the brush. You will notice on the roller brush itself there are two indentions on both sides of the brush that run the entire length of the brush. You can take a knife or scissors and run them down the brush on both indentions, which will help you remove the stubborn debris wrapped around them.
Also you'll notice on both sides of the brush that there is a yellow bearing cap on both sides of the brush. You may pull these bearing caps off, and remove any debris that is around these caps. You may also lubricate these bearings with grease or WD-40, to ensure the brushes spin fluently.
After you have cleaned the brushes and bearings, insert the brush roller back through the belt, and into the power brush. You'll notice that the bearing cap will have two sides. One side of the bearing cap has 1 groove in it, the other side has 2 grooves.
When you reinsert the brush back into the power brush, you may lower the roller brushes if the machine has been used a lot. If the roller brush is older, you will want to re insert the brush with the side that has 2 grooves facing upwards, and the side with 1 groove in it, facing down. In the first picture above, you will see that the side with 1 groove is facing upwards and is visible to the camera. The side with 2 grooves is facing down. This is because this brush is new. If your brush is older, you will want to reverse that, and have the side with 2 grooves facing upwards. When the brush is back into the power head, simply put the bottom plate back on, (IMPORTANT! Make sure that in the front of the machine the bottom plate is completely hooked onto the front of the power brush, there should NOT be any space in the front) Once you have screwed the plastic screws back into the power brush, in the front of the power head, push the bottom plate upwards to make sure there it is fastened tightly in the front.
I hope this helps you. If you have the larger, less popular SEB236 power brush, just send me an email, I'd be happy to walk you through cleaning the brush on this one also. If you have any questions about this repair, please feel free to email with any questions, I really enjoy sharing my knowledge, and passion fixing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Miele Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
