Question about SYMA Toys industrial Syma S032 Ready to Fly Gyro
S032 controller work intermittently - flying copper suddenly drops down without moving the controls. batteries are new
    Scholar:
  • 56 Answers
Did you mess with the wire that came wrapped around landing skid?
This is the antenna, and it should be coiled tightly without pulling on the connection to the circuit board, and ideally not in contact with too much metal. (pull it slightly away from metal frame piece above landing skid)
Remote antenna should be fully extended.
Normal range is 50-100 meters depending on surroundings and conditions.
Let me know if you still have trouble.
r
Posted on Sep 13, 2011
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
My syma s032 now won't hover consistently but moves up and down slowly of its own accord. I can compensate by continually moving the joystick. I did have a couple of crashes though they were...
Could possibly be weak remote batteries?
Also, the s032 has an incremental throttle (you should feel very light "clicks" when moving left joystick {throttle} up or down) that can sometimes make steady hovering a challenge. Syma helicopters are fairly durable, but crashes can make them kind of shaky. Be sure to quickly throttle down fully when you are about to have any kind of blade strike or crash. If you crashed outdoors, check to make sure no blades of grass or other foreign items are in near the gears, and check the shaft for anything wrapped around it that might be slowing one or both main rotors. (even a stray long hair can muck things up) Is it exhibiting any other symptoms?
Still getting similar flight time?
Hope this helps, let me know.
r
Jun 29, 2011 | SYMA Toys industrial Syma S032 Ready to...
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Hey has anyone had problems where the helicopter is flying fine then all the sudden it falls out of the sky. Ive replaced the batteries in the controller and charged the battery and it still does it.
Have you messed with the helicopter wire antenna at all? It's the plain wire that comes wrapped around one of the landing skids and should be left like that. Also, make sure the metal antenna on your remote is fully extended. Normal operating range is 50-100 meters maximum depending on surroundings and interference. Are any of these potentially the issue?
hope this helps,
r
Jan 03, 2011 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
My s032 dont seem to hover very well and back and forward dont work very well
are you sure the battery is fully charged the light on the charger
should shine brightly but you might of overcharged it if you have had it on for 90 mins
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
Hey I recently just bought the SO32 helicopter and am having trouble getting it to work. The helicopter is charged and the lights on it are flashing, but when I turn the remote on, the power light is...
The problem is the battery, I just got one for Christmas and overcharged the battery. I put a new one in and it works. The manual says never charge over 90 minutes.
Dec 25, 2010 | SYMA Toys industrial Syma S032 Ready to...
S032 won't fly higher than 0.5m. and for a few secondes. I bought 2 Syma S032 helicopters whith 3 lipo's. The first 3 a 4 times both choppers flow verywell. I have charged the batterie's so as told in the...
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
Nov 01, 2010 | SYMA Toys industrial Syma S032 Ready to...
Open Questions:
See all SYMA Toys industrial Syma S032 Ready to Fly Gyro Questions
SYMA Toys industrial Syma S032 Ready to Fly Gyro Logo
285 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
