Question about Dell Computers & Internet
I have a Dell S2009W monitor. I tried to change the resolution settings in an online game that I play to a finer resolution. It didn't work...lol. I get a an error message that the "timing" is incorrect. The error message is being sent from the monitor and reads: "Your current input timing is not supported by the monitor display. Please change your input timing to 1600x900@60mhz or any other monitor listed timing per the monitor specifications". The problem is that every time I try to launch this game i get the error, and I don't see how I can change my settings since the monitor is now set for something it can't support. I have tried to change the display options in properties for that particular app bot it is still trying to load with the improper "resolution/timing" i had selected. My regular window's display is fine. Any suggestions?
  • 155 Answers
SOURCE: I recently got a 1600x900 monitor and on the
If the monitor came with a drivers or profile disk, make sure to use that. Also, make sure the video card can run at that resolution. Check with the system or video card manufacturer.
You may want to post what kind of (a) system (for instance, "HP Pavilion D1321" (to make one up) ) and/or video card (from display properties - "Plug and play monitor on nVidia MX400") as well.
Posted on Oct 03, 2009
MalKontent68
  • 748 Answers
SOURCE: 16:9 resolution problem
You don't specify your machine type, or the operating system, but let's assume a desktop computer and Windows XP...
Was the monitor recognized properly by the video driver?
Go to Display Properties, settings, advanced, monitor and see if Plug and Play monitor is installed. All modern graphics cards talk to the monitor to discover it's capabilities and should adjust the available resolutions so that the monitor's native resolution is available for choosing.
If some other monitor is listed there, change it to Plug and Play monitor. If still having troubles, you can do two things:
- update the video driver for your graphics card
- find the monitor's .inf file (it should be on a CD that comes with the monitor, or can be downloaded from DELL site), and install this instead of the Plug and Play monitor or whatever you have in your monitor setup (as above, go to monitor - properties - update driver).
Posted on Nov 08, 2009
SOURCE: Lost the screen resolution 1600X900. How do I get
Windows 7 - Start, Control panel, Adjust screen resolution, Detect, apply OK.
I have a Dell ST2010 and have to do this every powerup as it forgets...
If anyone knows how to fix that I'd be grateful...
Posted on Mar 20, 2010
budmrtn
  • 11361 Answers
SOURCE: my computer display screen starts with the message
You need to set your PC video resolution to this monitor resolution, which is 1920x1080@60hz. You can do it by bootup in safe mode (hit f8 key while booting up), then select boot with VGA, once bootup, set the new resolution 1920x1080@60hz or something lower such as 1280x768 for now, reboot in regular mode, and reset resolution to 1920x1080@60hz. You may have to install driver if the 1920x1080@60hz does not show up in the list.
Posted on Apr 24, 2010
stefa_pesovs
  • 6 Answers
This works for me. I have Philips 220E
Posted on May 28, 2015
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Hi, I have this problem with my dell inspiron N 4010 laptop. Whenever i want to play games on my laptop it either crashes down or after the game is over i get a "Optimum resolution error...
The LCD monitors and laptop monitors nowadays have a 'optimum resolution'. The monitor likes to work at a pre-defined resolution.
Games play at a resolution previously set. Usually this differs from the optimum resolution of a LCD/LED screen. Then this error message will appear.
However, crashing of the computer might happen due to other reasons.
*Defective RAM *Not-so-good VGA *Viruses
You have to make sure the above problems are not the reason for crashes.
Also try playing somewhat older games. If the problem occurs due to your VGA not supporting the new games, older games will work fine.
Try these suggestions and let us know.
Good luck, and thanks for using FixYa!
Oct 30, 2011 | Samsung Digimax 4010 Digital Camera
Trying to download/play games but get this message: Input not supported - then my computer FREEZES and I have to reboot. This a brand new Dell Computer (but not monitor - monitor is 6 years old).
This is cause the game you are trying to play is configured to play in a high resolution but your Monitor not supporting this resolution. If you havent try to play older games, try to play an older game and see if this is happening again. Thanks. Please Rate my Solution.
Apr 28, 2011 | Acer AL1916W 19" LCD Monitor
When i play a game the monitor goes into power save mode and will not come out .i have a Alienware Aurora with a dell st 2410 monitor
This is usually due to a resolution problem. see if you can reset the settings to default in the game. sounds like you are trying to play game in a resolution the monitor doesn't support.
Nov 04, 2010 | Computers & Internet
Nov 08, 2009 | Dell Computers & Internet
Lost the screen resolution 1600X900. How do I get it back? Its a Dell S2009W. Worked fine until I had computer problems. Now all my photo people are fat.
You can set the resolution on the computer. Right click an empty space on the desktop and then click Properties. In the properties dialog box click Settings. Now use the slider to change the resolution. Click apply.
Sep 25, 2009 | Computers & Internet
Upgrading graphics card
according to the manufacture your card has the resolution up to 2048 X 1536 that is higher than what the monitor is telling you to set your resolution to. try going into your display options and ajust the resolution down to 1600 X 900. Also since your monitor is a dell an new it should come with an set-up disk for that monitor that should once intalled set the monitor to the correct graphics setting for you so you do not have to go through and do it manually. did your come with a disk? If not here is the link to download the drivers for your monitor.
http://support.dell.com/support/downloads/download.aspx?releaseid=R194543&formatcnt=1&libid=0&fileid=271546
please let me know if you need further assistance in this matter.
Dec 28, 2008 | ATI RADEON 7200 (64 MB) Graphic Card
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
392 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
