Question about GE GSL25JFPBS Side by Side Refrigerator
Water line leaks where line enters refrigerator
My 5 year old GE GSL25 refrigerator is leaking as well when using the water dispenser in the door. Removed kick panel to see better. The plastic water line on the door side of the union was improperly installed in a metal clip such that it was being crimped. This unintended pressure caused the water line to eventually fatigue and split. The door side of the water line needs to be replaced.
Posted on Jan 15, 2011
  • RoboGeek Jan 15, 2011
    My 5 year old GSL25 has the same problem. I removed the toe-kick and pressed the water dispenser. I observed water shooting out of the door dispenser water line on the door side of the union, water line. The water line was improperly installed in the metal clip pinching the line. The unintended pressure caused the line to split and fail.
    Not certain how to easily replace it yet, but know what the problem is.
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Water leaking from ice maker line
Is the fill tube (on the inside of the freezer) full of ice? If so, you need a new water valve and the tube in the back should just push inside of the rubber tube on the back of the unit
Mar 12, 2013 | GE GTS18XCSWW Top Freezer Refrigerator
Ice maker is leaking
The ice maker fill valve is faulty.This valve located at the back of ice maker is not functioning properly,so water is leaking. Change the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem. It`s infrequently located in the rear of refigerator usely where water line enters the electrically back of refrigerator. In essence the valve and electric head can be bought at any Appliance Parts store. --------------------------- thank you.
Feb 22, 2011 | Refrigerators
When ice maker draws water the supply line leaks from where it enters the refrigerator and makes a hissing sound. What is your take on this? it just started and the unit has not been moved in some time.
more than likely you have a friction leak in the water line the hissing sound is the actual water stream
hitting the wall,
the friction leak is common from the hose jumping when water pressure is first applied
a simple water union can fix this quickly and cheaply
Oct 03, 2009 | Maytag MTF2156GEW Top Freezer Refrigerator
SMALL OUTDOOR BEER REFRIGERATOR DOOR LEFT OPEN OVERNIGHT IT STARTED DEFROSOTNG AND THEN ACTED LIKE IT BULIT UP PRESSURE AND BLEW OUT AIR OR REFRIGERANT AND DOES NOT COOL ANYMORE
Hi, absolutely there's refrigerant (freon) leak check your condenser and evap. for rupture (broken lines) also check for oil, presence of oil means, refrigerant (freon) leak, plug ref, and listen, for hissing sound inside and outside of ref. try to locate leak, or call mechanic, repair leak, change filter drier and recharge, if your evap punctured, you should immediately disconnect ref, and dry all water from evap, prevent water from entering system, could damage compressor, or if water get into compressor, you will have to change compressor oil. yes, you surely have a refrigerant (freon) leak.good luck.
Aug 12, 2009 | Refrigerators
Icetube leaking water inside freezer and outside back of freezer
Your refrigerator needs a new water valve and possibly some new water tubing. You can find the correct part by going to sears.com and entering the refrigerator's model number in the parts search field. When you have the valve, shut off the water to the refrigerator. If you're not sure how to do that, just shut off water to the entire house. Be sure to run the kitchen sink after you shut the water off to relieve any presure and double check that the water is completely shut off.
Be sure to unplug the refrigerator before you start this project...water and electricity aren't friends! Using a 1/4" nut driver or socket, remove the cardboard or metal cover off the back of the refrigerator. Follow the water line to the water valve, unscrew the nut going to the valve, and remove the water line. There are 2 screws holding the water valve to the refrigerator cabinet; remove the screws and gently pull the valve out. Unplug the electrical connectors and remove the water lines. Take the new valve, connect the water lines and electrical plugs, screw the valve back into place, attach the water line and turn the water back to to test for leaks.
Since the valve has been leaking inside your freezer it would be a great idea to clean out your freezer and let the water tube and lines thaw. Find a place for your frozen food, unplug the unit and let it sit overnight with the doors open. Don't forget to remove the ice bin, as these make quite the mess when the ice melts. Once it's thawed, plug it back in, make sure the water is on and not leaking and enjoy!
Jun 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Water leaking from freezer door.
Yeay!!! Thank you soooo much!! I opened my freezer door for about 5 minutes and also turned the freezer temp warmer, and my water dispenser worked again. And thanks to you guys, i didn't need my husband's help figuring this out :-)
Feb 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water inlet ot ice maker leaks in to frezzer
Change the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem. It`s infrequently located in the rear of refrigerator ussualy where water line enters the electrically back of refrigerator. In essence the valve and electric head can be bought at any Appliance Parts store. It`s not a high cost part and be bought easily for it is mostly a standard part to buy. erroneously bring the model number and serial number and they can get the right one to replace it with.
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
242 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
