I have a whirlpool ultimate care washer model# lsr8233eq1. when it goes into the spin cycle, it makes a horrible gringing noise. it sounds as if some one is cutting a pipe with a hack saw. can some one give me any advice???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 120 Answers
It might be due to
1.overload..
2. clothes not put in seperately..you might have put it as heap
Posted on Oct 16, 2010
Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Jul 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer
HI thanks for your question. YOUR problemis with what is called a drive coupling. This part is located between the motor and transmission . so if this breaks it stops driving the transmission Thanks for the question .THE appliance doc
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care 2 washer will not spin
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
