Question about Compaq Presario 700 470024-192 Notebook
Installing XP to C700
Hi Shin Chan,
Hope you can help me with this. I've tried disabling SATA Native Support, manage to copy files to install XP. However, as soon as the notebook restarts, it's going through the same setup & copying files again.
How to i continue to install XP? Can you guide me step by step?
Thanks.
Cheers!
    President:
  • 1,257 Answers
First disable sata native support because after installing xp and restarting will crash it.so disable sata native support now when installation of window xp is complete ,reboot the computer and enter bios and select the first boot device to hard disk and also disable cd rom boot to disable .by doing this when computer starts it will start with hard disk and not with cd rom .
________________________________________________________
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
Please help me, I couldn't install win XP in Compaq Presario CQ42, blue screen was displayed 0xF78D2524,0XC0000034,0X000000000,0X000000000
For most hp Compaq laptop, when installing Win XP resulting in Blue Screen Of Death (BOSD)
Take note** Reset your Bios setting,
"Disable" ->SATA Native Support -> save & exit
Then install WinXP.
Hope it helps.
Aug 25, 2010 | Computers & Internet
I install new sata hdd 1tb. When i try to install xp system say there is no hdd install. But i can see hdd on bios.krish
Hi.
Xp will not detect the sata hdd you have to install the sata driver before the installation begins by pressing the F6 key or you can disable the SATA native support in the BIOS to install Xp.
Jul 24, 2010 | ASUS P5S800-VM Motherboard
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Jan 24, 2009 | Compaq Presario C700T Notebook
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
When i try to install windows xp sp2 it says "no hard disk detected" i also doesn't know how to use nlite.could u pls help me with a complete step by step method starting from nlite to completion of driver...
First of all, as this Notebook is installed with SATA Hard Drive, any retail version of windows XP will not be able to detect the Hard Drive because of which you are getting this kind of errors when trying to install XP.
However, to proceed with installing XP in your Notebook, I recommend you to disable the SATA Native Support option which will be present with Notebooks installed with Intel Processor and not with AMD Processor.
You can disable the SATA Native Support feature from the BIOS by following the instructions below :
Start or restart the notebook and start tapping the F10 key which will take you to the BIOS setup window.
In this, go to the System Configuration tab where you will find the SATA Native Support.
Press Enter to select it when the option is hilighted and set the option to Disabled.
Now, press F10 key to Save the settings and exit the BIOS setup window.
By doing this, the Hard Drive in the Notebook will be detected as IDE Hard Drive and you should be able to install XP without any issues.
Please not down that the SATA Native Support option should be set to Disabled even after installing the Operating System in the Notebook.
However, I need to have the Product Number of the Notebook wich can be found printed on a white sticker pasted at the bottom of the Notebook indicated wit P/N using which I can find the Hadware specifications of the Notebook and provide the appropriate drivers.
Oct 28, 2008 | HP Pavilion dv6000z Notebook
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
Xp professional installation on hp pavilion dv6700 cto notebook
The original Windows XP Installation CD, a freeware application named NLite and a blank CD.
we need the drivers for the SATA controller provided by the manufacturer.
When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Import and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver
Mar 17, 2008 | Microsoft Windows XP Professional With...
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1042050&admit=-682735245+1161793137260+28353475
Oct 04, 2006 | HP Compaq nc6320 Notebook
Compaq Presario 700 470024-192 Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
