Question about Maytag MAH8700AWM Neptune Front Load Washer
EVERYTHING WORKS FINE UNTILL IT GET TOWARDS THE END OF SPIN CYCLE THEN IT STARTS VIBRATING AND WALKING ACROSS THE FLOOR PLEASE HELP ? WE HAVE ALWAYS HAD THIS PROBLEM EVEN AFTER LOWES INSTALLED THE WASHER & DRYER
    Sergeant:
  • 454 Answers
First, make sure the 4 shipping bolts have been removed, and that the machine is level front to back and left to right BOTH! Some machines prefer to be high in the front. VERY IMPORTANT Must have a minimum of clothes & towels, sheets or blankets to wash. DON"T wash 2-5 item loads (small loads)
run machine at least 2/3 full of dry clothes. These machines are built to wash more per load, also because of the many technical parts of the machine, sensors and relays, the machine decides how much water to use not the user! Some "Old Schoolers" have a real issue with the lack of water and unclean clothing... most complaints are user error. Enjoy the new front loading technologies! Cheers! Happy Washing.
Posted on Jan 19, 2011
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Washer makes loud banging noise on spin cycle and walks across the floor. The drum rotates fine on other cycles and belt seems to be intact
Have you removed the bolts at the back of the machine. they are there to help stop it getting damaged in transit but if left in when in use it vibrates violently and moves a lot read manual and look at back to see if bolts are left in and remove them if so. hope this helps.
Dec 28, 2010 | Samsung WF337AA Front Load Washer
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
139 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
