Question about Philips 55P8341 55" Rear Projection Television
When i turn the tv on the power light comes on the just starts to flash 2 time stop 2times stop ect
  • 2 more comments
  • markchristia Oct 16, 2010
    when i try to turn the tv on the power button light comes on the the light on the button goes out and i here a click. then the power button starts to blink and nothing else happens. if i push the power button again it lights up i here a click then the light goes back out i here a click and the power button starts flashing. it flashes 2 times then stops then flashes 2 times then stop and keeps doing that. it wont do anything else the screen doesn't come on or anything. it does sound like the projectors try to start i hear a hum then the click and then the light starts flashing
    thank u for the advice and prompt reply. went to the just answer site and never got a response and they still charged me and i cant get my money back so thank you for being so professional
    I was very happy with this site. Your tech was very helpful and quick to reply. The other site I tried before this one didn't even respond to me.
    ya and there not worth a hoot 15.00 for nothing they wont get my business again if i still have troubles hopefuly i can get you again thanks
  • 712 Answers
Please explain the problem a bit more clearly.
Posted on Oct 16, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Oct 16, 2010
    It sounds like the problem of the TV transformer. It is a small, cheap matchbox type box found easily when the back cover is removed. It is easy to be spotted as it is wound by copper coils all around it. A simple replacement will solve the issue.
  • Sebin Punnacheril
    There should be a refund policy for just answer too. Check the site throughly. I don't use it. So I'm not well aware of it. But it would certainly have a refund policy. It's more expensive than FixYa right?
Iturned ignition key on off on off on off,and,check engine light blinked twice,then twice again,then blinked five times,then four times,then five times,then five times,can you tell me what that means
This may have altered the programming of the alarm or ignition cutout. Your car may have a body control module which may have been altered. It may be more helpful if you specify more details including what model car you have and if it has an alarm or engine immobiliser.
Nov 05, 2014 | Cars & Trucks
Wd62627
It could be your power supply board.
Jul 23, 2013 | Televison & Video
Calling for heat red light flashing 2times
Hi, pull the panel off the unit where the light is flashing. If everything stops working, then you have a switch around the perimeter of the panel that killed the power and you will need to tape it down to restore power to the furnace. Once this is done, ( if it even happened ) look on the panel or the unit for a strip of paper that will be glued there telling you what each code means, and what to do to solve the problem. 2, 3, 4567 flashes mean different things going on. It may have tripped a limit switch, flame roll out switch ect. These are manual reset switches, so you will have no problem resetting them. I hope this was of help to you.
Shastalaker7
A/C, & Heating Contractor
Sep 19, 2011 | Intertherm Heating & Cooling
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 02, 2008 | Canon i950 InkJet Photo Printer
WORKS 3 MIN AND SHUTS OFF
If it is the power LED that is flashing orange 2times every five seconds , it suggests that the Lamp Cover was not reinstalled correctly. Remove and reinstall it
Jul 13, 2008 | Panasonic PT-50LC13 50" Rear Projection...
No video, no sound, power button light on constant, front panel light flashing
have a good tech diagnose this and there is a commom problem with this set in the power supply but is not nessesary to junk the set some places rebuilt light engine if thats the case
Feb 08, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Philips 55P8341 55" Rear Projection Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
