Question about Garden
I have a friend that has a Lincoln Electric Ranger 8 (Onan gas engine) welder/generator. The engine will not charge the starter battery. Any sugestions would be apreciated. ThankX
  • civ77 Oct 16, 2010
    do you mean that you can start the engine but the battery doesn't hold a charge or that the engine wont start because the starter battery wont charge?
  • 5 Answers
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Posted on May 03, 2009
mamicheddy
  • 79 Answers
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
Posted on May 07, 2009
bubby001
  • 18 Answers
SOURCE: Need a wiring diagram for a Lincoln Welder
try this page http://content.lincolnelectric.com/pdfs/products/navigator/parts/P72.PDF
if ifs not what you looking for heres the service number for Lincoln
1-216-481-8100
Posted on Oct 26, 2009
SOURCE: My lincoln welder/generator with onan engine will
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Posted on Nov 25, 2009
  • 134 Answers
SOURCE: Onan generator: Pro 6000e: engine runs, no
Are you getting any kind of voltage output at all?
Posted on Nov 11, 2010
I am getting no flow of fuel from the fuel tank to the fuel pump. Have installed new fuel filter and full tank of gas. Does this have fuel shutoff valve or a screen in the fuel tank.
[PDF]Ranger 225 Product Info - Lincoln Electric
www.lincolnelectric.com/assets/global/...1/e689.pdf
Lincoln ElectricENGINE DRIVEN WELDERS ... 50-225A DC 15-25V CV Welding ... RangerĀ® 225) for aluminum and other alloy welding. .... equipped with valve for gas flow.
Oct 09, 2015 | Lincoln Ranger 225 Engine Driven Welder...
My welder revs up but wont put out full power
We need a better description of what is happening. I see many engine driven welders that when loaded up heavily the engine rpm drops because of needing a tune up or complete engine overhaul. Since the engine can't run at designed r.p.m. the welder won't put out "full power" With a better description of problem, Such as engine is not slowing down but will only weld at 100 amps experts here could help you better.
Sep 18, 2014 | Lincoln Ranger 8 8000 Watt Kohler Gas...
Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
Jan 25, 2013 | Lincoln Ranger 8 8000 Watt Kohler Gas...
Welding fine , then machine quit welding, would still rev up, but barely arch!
I had the same problem except it was with a miller welder. it was a bad ground connection on the ground cable. if you have an ohm meter. turn off your machine,but do not unplug it. check for resistance from chassis ground on machine to input ground if your input on the machine is good you may have a bad cable,input connection or the ground clamp may not be making a good connection to the cable. good luck!
Dec 21, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
The engine has low oil level shutdown. It may be the reason for stopping.
Use the welder only at level condition. Check the oil level, before every start.
If no result, find and check the oil sensor contact (if possible replace with good to check). Try with disconnected and shortened contact prior to buying a new one.
Other possible reasons you already checked
Aug 05, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
