Question about Sony NWZ-S615F Walkman Video MP3 Player
The songs on my mp3 will not play. They appear on the screen but no sound. THere seems to be trouble with the battery.
Yesterday when I went to my car, my mp3 seemed to be drained of battery. I went home and tried to charge it. It would not fully charge (it should say "full") but did seem to charge enough that the battery icon was totally filled in. Odd. Also, when charging, the circular arrows did not seem to keep circulating as they usually do. It would seem to freeze after several minutes. When I went to play my mp3, there was no sound for anything on the mp3. I tried my dock, my car jack, and the earphones. IN addition, the mp3 started turning itself off and on. Then stopped. Help !!! I need my mp3 for a road race coming up.
Aweragagasgasgas
Posted on Sep 21, 2008
  • 8,596 Answers
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
My ipod was playing, i went to change the song and screen was black. tried changing the song, turning it on/off, resetting it, nothing worked. it stopped playing after the song and remains black
Have you tried turning the lock switch from locked to unlocked. There will be a little circular switch on the edge of the ipod that will appear red next to if it IS locked.
Feb 28, 2011 | Apple iPod nano 2nd Generation MP3 Player
My IPod seems to be locked up. I can get a single tune to play repeatly, but it will not play like it did at first when it woulf play completelt whn on shuffle. It fully charged bur will not play unless...
I live close to a very large shopping area. I went to the Best Buy store, went to the "geek" counter and asked the young man on duty to look at my I Pod after telling him it appeared to be locked up. Within 1 minute he had it working correctly again. In some way unknown to me I had gone to settings and had told the i pod to play songs a number of times. He cancelled that setting and it worked like new. I remember telling you folks that iit appeared to be locked up and would only repeat the individual songs once over and over. He saw the trouble in seconds. I have extended my service contract but I wonder why. Thanks for your efforts to help me. William R. Andrews
Sep 30, 2008 | Audio Players & Recorders
Powerpack mp3 mf a3
The mp3 Sansa e250 Sandisk seems to work on the computer and shows all the stored music contents but when I try to paly the songs by itself "No Songs" message appears. No song or video is being played. Is there any solution to make it work as before?
Sep 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 280
ok buddy...it might be problem with the storage.. try to format the player once.. now the player will be fresh... now download all the songs and try whether its working fine... if the problem continues try to contact the player manufacturer for replacement
Sep 17, 2008 | SanDisk Sansa e200 MP3 Player
My IPod Does Not Seem to "See" My External Hard Drive
It sounds like the external hard drive might have been disconnected, which would cause iTunes to go crazy trying to find songs. iTunes was not developed to incorporate that kind of system, unfortunately. It likes all of its songs on the main hard drive where it sees them. There should be an option to "Consolidate Library" under the Advanced menu. That will move all of the songs into iTunes' set folder for music. Let me know what you find.
Sep 07, 2008 | Apple iPod classic MP3 Player
Rca mp3 player TH1101A
Either the DB is corrupt of the license on the songs expired - make sure the music service is completely up to date. If it is, then go to RCA's website and get the latest firmware update.
Jul 01, 2008 | RCA TH1101 MP3 Player
Sanza 2 gig
it sounds like you need to get a new battery. Your current battery might be strong enough to light the screen but not strong enough to launch the song. Thats only thing i can think of. Hope this helps! :-) please tell me if it does!
Jul 19, 2007 | SanDisk Sansa e250 MP3 Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
182 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
