Question about Sta Rite 1 Hp Above Ground Pump Ne641
Good Day My 8NE-l 1hp Sta-Rite pump was overheated and getting no pressure(water) Motor works but I will more than likely need an impeller with repair kit. Any suggestions? Frank
Is there a reset switch to press..?
Posted on Jun 09, 2011
Pool pump turns on, starts clicking then turns off
It appears that the motor is overheating, and then it turns off. There is a thermal overload switch that will turn off the heater, and when it cools back down, the motor will turn back on.
A few things to check:
  • Debris in the impeller
    • If so, remove it, this is causing the motor to overwork
  • Was motor / impeller recently changed?
    • if motor was downsized from the one prior, it is overworking, because the impeller is still sized larger.
    • if impeller was upsized with an undersized motor, the motor is overworking
  • Is the motor louder than normal?
    • The bearings are probably failing and the creating the motor to labor.
Good luck
Mar 11, 2015 | Sta Rite Sta - Rite 1hp Dura - Glas...
Pump shuts off in very hot weather
might have the wrong motor on it, themotor hp and SF sevice facto determin the total HP output of the motor. so say it's a 1hp with a 1.65 sf it's a 1.65 hp motor ..the impeller detrmins the hp needed, it should have numbers and letters on it. welcome to my world fun huh
Jul 10, 2012 | Sta Rite Sta - Rite 2hp Max - E Pro...
I have a 1 hp Sta-Rite Centrifugal Pump, MPRA6#-147L. When on, water is coming it but the area with with filter is not filling up. I get no pressure on the filter and very little water is going to the...
CRACKED LID BAD LID O-RING,SUCTION LEAK, OR CLOGGED IMPELLER, LOOK AT YOUR BASKET IF IT HAS CRACKS, CHANCES ARE THE IMPELLER IS GOT **** IN IT. SPLIT THE PUMP AND CLEAN OUT THE IMPELLER , GET A NEW BASKET ASAP.. REMEMBER TO (PRIME THAT PUMP) AFTER ANY REPAIR !!!!
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jul 23, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I'm installing a 8NE-L , 1HP pump . How far can I run my 12/2 wire for 110 volt application?
The FLA (Full Load Amps) for a 1 HP single phase motor is 16 amps at 115 volts. 5% is the maximum allowable volt drop from the main electric panel to the pump per NEC (National Electric Code). When these values are plugged into the volt drop formula, such as this one:
http://www.nooutage.com/vdrop.htm
90 feet is the maximum allowable distance for a #12 copper rated at 75 degrees C.
May 03, 2011 | Sta Rite 1 Hp Above Ground Pump Ne641
How do u prime the pump?
If the pump is holding water at the pot the first thing to check is the pot lid "O" ring and the pot lid for cracks. Then you will need to check the suction line for leaks Without seeing your system this is about all I can help you with. Good luck.
Mar 09, 2010 | Sta Rite STA-RITE IMPELLER 1HP FULLRATE &...
I have a sta rite dura glas 1HP pump and can't figure out how to get the impeller off. Can you tell me?
Lock the shaft at the end where you electrical connections are made (disconnected of course!) and spin it off counterclockwise.
Aug 11, 2009 | Sta Rite Dura Glas 3/4 Hp In Ground Pool...
Shaft seal leaks on sta rite pump?
You need to get to the shaft at the back of the motor to hold it while you use water pump pliers or the like to turn it off. It will unscrew in the regular direction but if it has a set screw to hold it in (You will find this at the center of the impeller) this will be a left hand screw so you will go clockwise to loosen it. This should get the impeller off. If not you will need to put a screwdriver in the side of the impeller and give it a hit to lossen the impeller. Good luck.
May 17, 2009 | Sta Rite 1 Hp Above Ground Pump Ne641
Sta Rite 1 Hp Above Ground Pump  Ne641 Logo
214 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
