Question about Dishwashers
Matsui slimline dishwasher don't know what symbols mean one is a pot with a tray underneath. One is just a pot and the other is a shower with a tray type line at an angle
    President:
  • 1,140 Answers
OK . . .
Pot with tray underneath is "heavy soil" - this will be a long wash
Pot only is "medium soil" - this will be a standard wash
Shower with tray / line is "light soil" this will be a quick wash / rinse
Please rate this solution if you find this helpful. Thanks.
Posted on Oct 16, 2010
Im fitting a show tray in an en suite the stair way comes up underneath so if I fit the shower tray to the wall about 3" of the tray will poke through the plaster board showing above the stairs.
Hi Chris:
Sounds like you've identified the two logical choices.
It may be preferable to raise the shower for at least 3 reasons:
1) Headroom and aesthetics of the stairway ceiling will not be affected.
2) The installation of the shower drain trap will have more space available.
3) It will be easier to provide structural support for the shower base.
Hope this helps.
Cheers
Apr 05, 2016 | Home
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
Pots and pans light keeps blinking and not working on Whirlpool Gold Dishwasher - what do I do?
Pots and pans requires HOT water. If your heater is not working it will not run the cycle. Possibly the heating element is bad or has become disconnected. Only has two wires coming in from the bottom of the dishwasher (underneath behind the kick panel). Do not touch them unless you know power to the DW is off. Heating element is nothing but a high resistance wire in a tube so you can check it with an ohm meter. Continuity means it is good. AS LONG AS that continuity is not with the outside tube.
Not hard to replace it but up to you to decide if it is more trouble than you want to do.
Sep 15, 2012 | Whirlpool Dishwashers
I don't know what the symbols 0 I II mean on my slow cooker SCV300SL
It is a universal symbols,0= off, 1=low heat, II= high heat. Hope this helps you. Rob
Oct 02, 2011 | Crock Pots & Slow Cookers
Hi there. I have a Matsui MF145 slimline dishwasher and having a problem. When I press the on/off button I would usually then press the program indicator button (usually the first indicator - pans) and...
try to clean the unit, ofetn when the machine is dirty, some sensors are fooled thinking there's some problem. be sure there's no jam on mechanical parts.
Feb 02, 2011 | Dishwashers
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Matsui dishwasher wont fill up with water
check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Jan 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Symbols on the Dishwasher
The circle that looks like a sunny side up egg? That's the super hot sanitary rinse.. the other symbols simply mean lots of plates only, plates with glasses, or the short section means rinse.
May 02, 2008 | Danby DDW496W Free-Standing Dishwasher
Dishwashers Logo
297 people viewed this question
Top Dishwashers Experts
